Question about Sony Televison & Video
Sony SXRD KDS-50A2000. Screen was turning green and bulb was getting old. Replaced bulb with Sony recommend bulb.Screen is greener now and picture is terrible. Is it repairable? Or junk it. It's about 4 years old.
  • 1 more comment
  • caboatman Aug 23, 2010
    The actual picture is great except for the color. the upper corners are dark, lower corner are normal. can't afford high repair bill
    I would like one more expert comment before I junk the TV. Can anything be salvaged like the bulb that is only a few months old?
    The comment on a solution was helpful in determining what I need to do which is junk the TV at a loss. I doubt Sony would give me a discount on anything. I do not understand the remark on "Show you appreciation by commenting on Sony. However, Mr. ginko , thank you very much for the information.
  • Sony Master
  • 19,396 Answers
Hi.
The green haze on this model is a factory defect.
Apparently most of the time the problem is caused by an optical block defect. Optical block is a very expensive part, and reapir will cost nearly same value of TV.
Here a forum on problem.
There is a class action that resulted in a partial settlement. Call sony and quote this document, you should be entitled to a total refund on optical block purchase, or to a big discount on a Sony replacement TV.
Do not forget to accept.
Regards.
Posted on Aug 23, 2010
  • 1 more comment
  • steve_girard Oct 06, 2010
    call SONY at 888-993-7669 give them the serial number and about when you purchased the set and they will give you 3 choices....#1. a new top line 52' lcd for $550 delivered, #2. a 55" lcd for $275 delivered, #3. a free 46" lcd again delivered. They will not pay for repairing the set....they said it will fail (optical block) again in time.
  • Ginko
    Ginko Oct 06, 2010
    Hi.
    I am glad to hear that calling Sony helped.
    Thanks for the feedback.
    All the best.
    Ginko.
  • Geo Sky Mar 10, 2013
    ginko was the best & only answer too late for sony to help now
  • Sony Master
  • 17,130 Answers
The fault might not have been associated with the projection lamp but could be the fault or failure or weakness of the LCD imager.
It is possible that this section is faulty, the processor or the display which is giving out the green colouring.
Remove the main boards and check if there is any dry soldering in the sections , use a good low power anti static ironto do this touch up job.
replacement of the board might be expensive and not recommended but if you can salvage one from a projector tthat was dumped for other problems, like lamp , it would be easier.
Please check all connectors, plug in sockets.
Hope you find this error.
Good day
  • Sony Master
  • 5,138 Answers
I think you may just want to junk this set,unless you can find a good deal on a rebulit Light Engine/optic block Assy A-1203-196-A is Part number /Price is 3,100.00/ refud for old part 2270.00 then Cost of part is $900.00
Encompass Parts Distrbution has them in stock
1-800-638-3328
  • ladywinn
    ladywinn Aug 23, 2010
    If you decide not to fix this Set ,you can post Parts, Lamp ,Ballast Board Ect... and Front screen plate for sell on Ebay.
How to get a picture on sony FULL HD 1080
Hi. Not shore of this model but could be a bulb replacement is needed, Or one of the filter covers may not be making contact.
The red light is indicative of error rather than working ( green ) or standby ( orange ).
I hope you get it sorted.
Sep 12, 2014 | Sony XL5200 LAMP - TV KDS-50A2000,...
I have a Sony KDS-50A2000 and when I try to power it on, the green light flashes like normal and then without the screen ever lighting up, the power light flashes red 9 times, then pauses and repeats this...
Now that you have the blink code, Google your make and model with blink codes added to the end. This will show you links to sites that will tell you what the nine blinks mean.
Sep 17, 2011 | Sony KDS-50A2000 50" HDTV
I have a Sony SXRD KDS-50A2000. The picture has started going on and off- on 5 seconds then off 30 seconds to a minute. The bulb was replaced 10/1/09 and the bulb indicator is not flashing or anything. ...
Bulb was replaced within a year.That the first thing to replaced.The Ballast board is dead,you hear alot of clickings too?The Ballast board,that the board help to ignite the projection lamp.
Aug 14, 2010 | Sony KDS-50A2000 50" HDTV
My Sony SXRD power led is blinking and the picture
your power supply has failed repair/replace it
Mar 20, 2010 | Sony KDS-70R2000 70" SXRD TV
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
Sony KDS-50A2000 - bulb replaced but picture still yellow
Hi,It sounds like a light engine problem Sony is having.Basically the light of the lamp goes through tunnels that have mirrors that direct the lamp to 3 main LCD chips,These 3 LCD chips are blue,green, and red they blend to create the image and colors.When they start to fail you'll get color discoloration like what you are getting.You will need to replace the optical block because unfortunately they don't sell the LCD chips by themselves.GOD BLESS YOU!
Oct 06, 2009 | Sony KDS-50A2000 50" HDTV
Green cast on all channels
Hey Sandjk, I have a 3 yr old sony 60a2000. It has been turning green for the last 3 months. I thought it was the bulb needing replacement, so I just changed it. $250 down the drain. Its no better at all. I have to go to settings-picture-custom- advanced settings-white balance- and take the g-gain and g-balance to minimum values. do it for the cool and warm 1 settings. then when you cycle thru the cool neutral warm settings you will see a big difference. Not great but watchable. let me know what you think or if you found a better solution.
SandyP.
Apr 23, 2009 | Sony Televison & Video
My tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
Jan 02, 2009 | Sony KDS-50A2000 50" HDTV
Sony KDS-50A2000 screen is in green tint
My Sony KDS 50 A2000 is 17 months old. Its the 50 Inch SXRD projection model. About two weeks ago the screen developed a green tint with cannot be tuned out, then a few days later the message began to appear on the screen that the bulb was nearing the end of its life and must be replaced.
Fortunately I have the Circuit City extended warranty.
I called and within just a few days a serviceman came out and replaced the projection bulb.
The Result: No change in the picture, the green tint remains on all channels, so I'm awating the next service call. Under the service warranty they have the option to repair or replace this set. If indeed this is the light engine (optical block) which I suspect and its going to cost $1,000 or more I may be looking at a new set.
When it works this is a great TV, but I have had three Sonys now including two other standard CRT models and now this one joins them in the junk heap, the other two also bit the dust after just about two years. Is it time to give up on Sony?
I know they have a class action suit on a similar model for this same problem. Caveat emptor
Jul 31, 2008 | Sony KDS-50A2000 50" HDTV
Televison & Video Logo
631 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
