Question about Maytag Dishwashers
The door that releases the detergent in a Maytag Jetclean Dishwasher EQ Plus is not opening. The prewash side has openings that allow the detergent to dissolve, but the main wash side never opens preventing the dishes from getting washed thoroughly. Any ideas?
    Problem Solver:
  • 6 Answers
There is a spring mechanism that is located behind the flap, inside of the door of the dishwasher. You may have a spring broken in there. Take the plastic cover off the inside the door and examine
Posted on Aug 12, 2012
I have exactly the same problem with a maytag mdw17,,,,,any ideas
Posted on Sep 05, 2010
How do I replace myself the detergent/rince aid assembly on a Maytag Jetclean dishwasher EQ plus model #MDB9150WB? I only need to replace the door, but I don't see a part for that, just the entire...
Carol,
This is a simple repair. Remove the screws around the outer door edge and separate the door. The dispenser is clipped into position with several screws. Remove the screws and push the dispenser through the door.You can purchase the part from the link below.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
I have a 13 year old Maytag that works great. But recently the flipper door that dispences the dry detergent doesn't open during the wash cycle. I've tried cleaning it thoroughly, but that hasn't made a...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 17, 2010 | Maytag 24 in. MDB6600A Jetclean II...
Maytag dishwasher jet Clean EQ Plus Leaks out the bottom of the front door on the right side!!!
First, examine the gasket around the door or dishwasher front for tears or holes. If the gasket looks good, the door may have been flexed during installation or while loading / unloading. Open the door half way and try to flex counter clockwise. This should straighten out the door and allow the seal to contact properly.
Sep 08, 2010 | Dishwashers
My compartment doesn't open and does not disolve the detergent
if the door opens and it doesnt disolve the water isnt hot enough
May 30, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus MDB7100AWB
the door seal has gone better change the door surround seal also. check for case damage and obstructions aswell.
Mar 14, 2009 | Maytag MDB7100AWB Dishwasher
Panel lights all flashing when trying to start a load
Try pressing delay/resume then drain/off. In some cases you might need to do delay/resume then drain/off twice.
Dec 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
May 22, 2008 | Maytag PDB3600A Built-in Dishwasher
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Dishwashers Logo
364 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
