HOW DO I GET THE CARTRIDGE HOLDER TO MOVE INTO POSITION SO I CAN CHANGE THE BLACK CARTRIDGE?
  • 105 Answers
Turn the printer On and try to change the cartridge
Posted on Aug 22, 2010
How do I get cartridge holder to move to change position?
Hi there bud. Don't worry. Explaining it via text wouldn't be the ideal way so I attached a link to a easy video guide , please do watch it . Hope it will help ya. Good luck!
Note :
This is the best video guide I found and it's for everyday general printer .
Aug 02, 2016 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Cyan toner missing message. on magicolor 330
Firstly - remove and reseat the cartridge. If problem remains: Replace the cartridge with a new one. It is possible the new cart is faulty. If problem remains: Cart Sensor unit should be replaced as follows (If you need a copy of the service manual, contact http://www.TheServiceManualShop.com) Removal 1. Remove the Fuser Assembly (RRP 9.80). 2. Reach inside the empty Fuser cavity and slide the Cartridge Sensor Holder forward to unlatch the Holder from the printer frame (Figure 1). 3. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame and the Holder is free of the frame. 4. Disconnect P/J 87 from the Cartridge Sensor. 5. Remove the screw securing the Cartridge Sensor to the Cartridge Sensor Holder and remove the Sensor (Figure 2). Replacement 1. Position the Cartridge Sensor onto the Sensor Holder so the LEDs face out. 2. Line up the position tab and screw hole on the Sensor with the two holes in the Holder. 3. Use one screw to secure the Cartridge Sensor to the Sensor Holder. 4. Reconnect P/J 87 to the Cartridge Sensor. 5. Position the Holder against the Holder cutout in the printer frame. 6. Move the Sensor wire harness so it exit through the cutout at the rear of the Holder. 7. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame. 8. Push the Holder forward until the front latch secures the Holder to the frame. 9. Reinstall the Fuser Assembly (RRP 9.80). If the problem remains, then the MCU PWB will need replacing. This could put the machine Beyond Economical Repair.
Jun 12, 2007 | Minolta magicolor 330 EX Laser Printer
Can't get WF-3520 cartridge holder box from far right position so I can remove & replace an ink cartridge
To force cartridge removal do the following
Shut down the printer (if it is powered on)
Now turn the printer on
When you see that the carriage starts to move instantly unplug the printer power cable
Now you can move the carriage freely by hand!
Move it in the cartridge change position and change the cartridge you want to change
Do it just if the printer has a defective cartridge and the carriage won't go to the cartridge change position :)
Hope you found it useful!
Dec 17, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
In the maintenance section Inkjet Cartridge Repacement does not work. The cartridge does not move into position to be replaced.
Hi!
Does it make a grinding noise when you change the button to replace the ink? As if it is trying to move the cartridge holder to a position where you can replace the ink?
If the cartridge holder has like a lock to keep the ink cartridges in place, try to use a flat object that you may insert to push it down.
One or two things- you may have not close that ink latch properly so it won't move, or the mechanism for printer is damaged.
Thanks for your time and using Fixya Online Support. Cheers!
Jan 02, 2011 | Epson Stylus Photo R300 InkJet Printer
How do u change the ink in the epson 6000?
Things You'll Need:
  • Replacement cartridge (black, cyan, magenta, or yellow)
  1. Step 1 Turn on the printer and press the Color button.
  2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
  3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
  4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
  5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
  6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Shows black ink empty after new cartridge inserted
Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
1. Make sure the MultiPASS is plugged in.
2. Open the document tray.
3. Lift the document guides to open the ADF (Automatic Document Feeder).
If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
Or slide the Document Feed Lever to either the automatic or manual setting.
4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
Press thingtopress.gifto move the cartridge holder.
5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
lockinpos.gif 8. Press thingtopress.gif.
The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
9. Close the ADF (Automatic Document Feeder).
10. Close the document tray.
Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
Apr 11, 2009 | Canon MultiPASS C530 InkJet Printer
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
I need to replace the color ink in my Epson stylus color 740
To force a Cartridge change press and hold down the Paper feed (load eject) button for over 5 seconds and the cartridges will move into a change position. Please note: if the cartridges move to a position where only the Black cartridge can be changed pressing the Paper feed button once will move the head so that the colour can be changed.
Before changing the carts it is recommended that you run the head cleaning utility.
When you have poor print quality and have tried the head cleaning utility it is recommended that you replace the cartridges. Ift the red lights aren't on to indicate the ink is out you need to force the cartridges into a change position. To do this press and hold down the paper feed button (load eject) for over 5 seconds and the cartridges will move into a change position. Please note: if the cartridges move to a position where only the Black cartridge can be changed pressing the Paper feed button once will move the head so that the colour can be changed.
Regardds
Jan 04, 2009 | Epson Stylus Color 740 InkJet Printer
Cartridge holder for BJC-4400
I have the cartridge holder you are looking for and wiould be glad to trade you for the black only cartridge holder. PRB4u@bellsouth.net
Jul 18, 2008 | Canon BJC 4400 InkJet Printer
k24674
jasbo
jasbo
