Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Will not autofocus - Canon EF-S 17-85MM F/4-5.6 IS USM Lens
    Problem Solver:
  • 7 Answers
This is a good lens, barring any drop damage, try cleaning the contacts on both the lens and the camera body with a q-tip and a rubbing alcohol. Of course, double check the AF/M settting on the lens and camera (i've bumped to the off position B4 and not realized)
good luck!
Posted on Aug 23, 2010
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.
The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
Nov 27, 2012 | Polaroid Wireless Performance Battery Grip...
I have a AF Nikkor 70-210 which I use with a DSRL camera. But I want to buy a analogic one. Should I buy an AF one, or the lens will still full working (including the autofocus) with a manual one, like a...
The lens will work with any Nikon film SLR, including the FG-20. However, the FG-20 is not an autofocus camera. Whether the lens is capable of autofocusing or not, you'll still have to focus manually. With a newer autofocus camera, such as the N75 and N80, the lens will autofocus.
Mar 13, 2012 | Cameras
What digital nikon cam works autofocus in a nikkor micro AF 105mm f/2.8D?
This lens lacks the autofocus motor, so it will only autofocus on cameras with the motor. This lens will autofocus on every Nikon digital SLR except for the D40, D40x, D60, D3000, D3100, D5000, and D5100. It will autofocus with the D1 family, D2 family, D3 family, D50, D70, D70s, D80, D90, D100, D200, D300, D300s, and D700 (I hope I haven't left any out).
Jul 03, 2011 | Nikon Cameras
Which Nikon S.L.R. cameras can I use my 70/300mm AF-S Nikor and still maintain auto focus, it is currently on a D40x
Every one (assuming the camera supports autofocus in the first place, of course--old film Nikons didn't). The lens has an autofocus motor, so the camera doesn't need one.
Film Nikons supported autofocus starting with the N2000. (Actually, the F3 also had autofocus capabilities, but used a different system). All the digitals support autofocus.
May 15, 2011 | Nikon Cameras
Just bought a new eos d600 . How do I turn on the autofocus?
Set the autofocus switch on the lens to AF. Press the autofocus button on the camera (right on the cursor pad) to bring up the AF mode. Use left/right or turn the command dial to select the desired autofocus mode and press SET.
It's in the "Changing the Autofocus Mode" in the manual (page 83 in my copy).
Mar 23, 2011 | Canon PowerShot SD600 Digital Camera
Autofocus
Reset.
Press and Hold the INFO button near the trigger and 'I' button at left side bottom for few seconds. Once the information appears on the LCD screen, your autofocus should be working.
Orelse, carry it to an authorised service centre.
May 14, 2010 | Nikon D5000 Digital Camera
My Sigma 70-300 doesn't workin autoFocus mode. It
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
Oct 14, 2009 | Sigma 70-300mm f/4-5.6 DG Lens
Can't autofocus Nikon 50mm f1.8 lens
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
Jun 11, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D50 autofocus
Same happened to mine ,Its almost as though the motor has dis-engaged.I SOLVED MINE BY FORCING THE FOCUS RING WITH AUTOFOCUS ENGAGED THIS SEEMS TO HAVE RE ENGAGED THE MOTOR .HOWEVER BE CAREFUL I HAD LITTLE TO LOSE MINE WAS STILL UNDER WARRANTY WHEN I DID THIS.Its perfect since.
Jan 12, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
