Question about LG BP6000ER Air Conditioner
Hi. We've been running our LG BP6000ER window unit air conditioner for four seasons. We've made seasonal efforts to clean the interior with a hose, but this year we're noticing a strong mold/mildew smell eminating from the unit particularly when the compressor cycles off. Short of taking the unit to a professional to be cleaned is there anything we can do to either (1.) clean it more thoroughly-- perhaps by removing certain parts or (2.) to kill the mold with a spray of some kind. We'd be grateful for any suggestions. Thanks.
  • 139 Answers
Take it outside .get the hose .buy some coil cleaner hardware store .clean the coils good.. both of them .try to be carfull of the controls not to get them to wet ..cover them if you want ..after cleaning coils tilt unit to remove most of the water let it dry, use a fan its quicker should do the trick .it will work like new and smell better
Posted on Aug 23, 2010
My LG Model LP6000ER blows cold air for about 5 minutes and then the compressor shuts off
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 10, 2011 | LG BP6000ER Air Conditioner
Tip
Air Conditioning Tips & Tricks You Must Know!
  • Try setting your thermostat between 72°F and 78°F. Each degree setting below 78°F will increase your energy consumption by approximately 8%. As you can see, that can add up to a lot of money over a year.
  • Inspect and clean both the indoor and outdoor AC/Heating coils. The indoor coil in your air conditioner acts as a magnet for dust because it is constantly wetted during the cooling season. Dirt build-up on the indoor coil is the single most common cause of poor efficiency. The outdoor coil must also be checked periodically for dirt build-up and cleaned if necessary.
  • Check the refrigerant charge. The circulating fluid in your air conditioner is a special refrigerant gas that is put in when the system is installed. If the system is overcharged or undercharged with refrigerant, it will not work properly. You may need a service contractorto check the fluid and adjust it appropriately.
  • Use bath and kitchen fans sparsely when you are running the air conditioning system.
  • Reduce the cooling load by using cost-effective conservation measures. For example, effectively shade east and west windows. When possible, delay heat-generating activities, such as dishwashing or baking, until the evening on hot days.
  • Try to not use a dehumidifier at the same time your air conditioner is operating. The dehumidifier will increase the cooling load and force the air conditioner to work harder, which in turn increases your utility bill.
  • Over most of the cooling season, keep the house closed tight during the day. Don’t let in unwanted heat and humidity. If practical, ventilate at night either naturally or with fans.
Room Air Conditioning Units
  • The unit should be level when installed, so that the inside drainage system and other mechanisms operate efficiently. If possible, install the unit in a shaded spot on your home’s north or east side. Direct sunshine on the unit’s outdoor heat exchanger decreases efficiency by as much as 10%. You can plant trees and shrubs to shade the air conditioner, but do not block the airflow.
  • Set the fan speed on high, except on very humid days. When humidity is high, set the fan speed on low for more comfort. The low speed on humid days will cool your home better and will remove more moisture from the air because of slower air movement through the cooling equipment. Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing electricity use.
  • Set your air conditioner’s thermostat as high as comfortably possible in the summer. The less difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be. And don’t set your thermostat at a slighter setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Don’t place lamps or televisions near your air-conditioner’s thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
Proper maintenance of your air conditioner will also save energy. Be sure to do the following:
  • At the start of each cooling season, inspect the seal between the air conditioner and the window frame to ensure it makes contact with the unit’s metal case. Moisture can damage this seal, allowing cool air to escape from your house.
  • Check your unit’s air filter once a month and clean or replace filters as necessary. Keeping the filter clean can lower your air conditioner’s energy consumption by 5% to 15%.
  • Occasionally pass a stiff wire through the unit’s drain channels. Clogged drain channels prevent a unit from reducing humidity, and the resulting excess moisture may discolor walls or carpet.
  • *In the winter, either cover your room air conditioner or remove and store it.
on Aug 19, 2010 | Heating & Cooling
I have a GE AGMO8LJG1 window air conditioner. Just put it back in the window for the season. The motor runs, but no air comes through. What do you think is wrong?
heatman101
Jun 16, 2011 | GE AGQ10AJ Wall/Window Air Conditioner
I have a ESP412J-L window unit purchased last summer. After putting the window unit in for this season the ac started off giving cool air up to about a week ago, now it does not give off the cool...
Hello, if you have cleaned the unit, checked the filter , cleaned the coils then either the unit is low on refrigerant due to a leak or the compressor is not engaging due to a bad thermostat on the unit, bad capacitor, or the compressor itself is shot. If its under warranty i would take the unit back to the store and getna replacement.
Jun 12, 2011 | Haier ESA312 Energy Star Window Type Air...
The air conditioner won't cool the room
not change, just check to make sure clean, you can run water over them to clean.
Jul 07, 2010 | Sharp CV-P10MX Air Conditioner
The best pressure of gas in a split ac in
65 psi is the ideal pressure remember its not exceede from this pressure.
and it is valid for all season
Jun 05, 2010 | LG LSC121PMA Split System Air Conditioner
My air conditioner is not producing any water
It will take a full season of runnig to produce a cup of water. Most moiisture evaporates and is exhausted out the hose.
May 31, 2010 | Kenwood KW85 Air Conditioner
Lg lwhd1200fr air conditioner is leaking water inside, best ideas on how to solve this problem?
REPOSITION UR WINDOW AC. RAISE FROM FRONT ABOUT 1/2 " SO WATER WILL DRAING DOWN TO CONDENSER OUTSIDE.
Sep 12, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
My fujitronic is leaking water. Any solution?
hi friend,
Instructions
  1. Step 1 Pull the air conditioner from the window on a mild, sunny spring day. The sun shine will help in rapidly drying out the air conditioner after you perform the next routine process.
  2. Step 2 Place the air unit on a firm surface. Preferably a concrete slab or a few old boards. Do not place the unit on grass or dirt.
  3. Step 3 Use the screwdriver and remove the outer metal housing of the air conditioner. There are generally 4 to 6 screws along the lower edge of the cover that holds it to the frame.
  4. Step 4 Observe the inside of the air unit. Note that there is a plastic drain tray on the bottom. This drain tray carries away the condensation water from the cooling coil and allows it to flow to the outdoors and drip to the ground. The drain tray is plugged from last seasons collection of dust and bacteria growth.
  5. Step 5 Use the cup measure and pour some house bleach into the plastic tray. Allow the bleach to "work" on the nasty solids that have collected there for about 5 to 10 minutes.
  6. Step 6 Connect the gardenmag-glass_10x10.gif hose to the outdoor spigot and attach the spray nozzle to the hose.
  7. Step 7 Spray in the interior of the air unit with the moderate pressure from the spray nozzle. Force the water into the plastic drain tray and remove all of the solid debris that is laying there. Spray the interior and exterior coils as well since you have the unit cover off. You will have to remove the interior filter as well. Clean the filter while it is exposed.
  8. Step 8 Place another cup of bleach into the plastic drain tray and allow the liquid cleaner to set for about 5 to 10 minutes than thoroughly rinse the unit with fresh water. The inside area should be thoroughly clean.
  9. Step 9 Allow the unit to completely dry in the sun. When dry, replace the exterior cover and place the unit back into the window. The unit will be cured of leaking for another cooling season.
Tips & Warnings
  • Weekly cleanings of the interior filter will help in alleviating bacteria build up in the drain tray. Living in an outdoor dusty environment may create the need to perform the bleach cleaning more than just once a year
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Fujitronic FA-1300 Air Conditioner
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
LG BP6000ER Air Conditioner Logo
139 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
