My samsung R519 will not turn on. The battery is fine. However, when putting it on the on light goes on but the others dont. You can feel the fan begin but nothing? Any ideas?
  • 942 Answers
If you feel that the fan does not move the all, that is the main cause of your problem. To reseat the fan, kindly turn off your laptop, remove cables & battery, press and hold power button for 8 secs, remove the screws at the back of the battery, remove the hard drive, remove the optical drive, and then reseat the fan. Then insert back the optical drive, hard drive, screws, cables and battery then turn on the laptop. IF it did not work, you need to call Samsung to replace your fan.
Posted on Aug 22, 2010
Samsung R519 irregular beeps on startup
check your ram it could be faulty.or over heating,check and make sure your fan is running.if its the fan get a hoover and clean it out.
Apr 29, 2014 | Samsung R Computers & Internet
Flashing orange laptop light on samsung laptop
If your battery is six years old, it has done very well and you have looked after it. I would think that a new charger will fix your problem.
Dec 21, 2013 | Samsung R519-53S Notebook
How to tell if a hard drive needs replacing on a samsung r519
1. If you have blue screen give us the exception code (0x000000) 2. How did you get to this point? 3. What is the condition of you install disk? Windows setup could just be messing up because the windows disk is damaged. Find an OEM copy of windows and set it up to boot from flash drive or external drive (CDs at prone to damage if you want a reliable windows install only use optical media if its in pristine condition.)
Jul 28, 2013 | Samsung R517 R518 R519 R522 Laptop Lcd Led...
Ive got the Samsung R519, just bought a new battery for it but doesnt seem to have made a great deal of difference, its only 2yrs old! Wont turn on when on adapter & battery removed & no charging...
From the description you have motherboard issues, sub out the ram memory one at a time to see if you can get it started, no change! the dc jack in the laptop is a common source of trouble from no power to intermittent operation, at this point the laptop will need to be taken apart for further examination.
Jul 03, 2012 | Samsung R519-53S Notebook
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
What's your problem?On going problems with Samsung R519 laptop after all the advise I tested laptop on separate monitor and it worked fine with no problems I bought new screen lead and still had p
The external monitor has proven there is no problem with the video graphics card, I'am concerned that customers have complained about faulty screens.
I have changed a lot of displays without issue, there is a major circuit board mounted behind the screen that plays a roll in picture production so if something goes wrong you get all kinds of symptoms from fuzzy images to multi color lines to a blank screen. I would suggest getting your money back because of his track record, also go online to Samsung and contact customer support and the technical department to see if something was over looked. Question! is this a new or used LCD display?
Apr 06, 2012 | Samsung R519-53S Notebook
Samsung R519 shuts down unexpectadly
Suspect Samsung R519 is dirty inside.
http://www.cnet.com.au/samsung-r519-339300512.htm
The cooling system for the Samsung R519 is the Cooling Tube, Heatsink, and Fan Assembly.
The Fan Assembly consists of a Fan, and surrounding cage. (Shroud)
The Heatsink is a thin piece of metal, that has Tall, Thin, fins protruding from it.
The fan's blades, center hub, and surrounding cage may become clogged with 'Gunk'
{'Gunk' = Dirt, dust, hair, food crumbs, lint, etc}
The fins of the Heatsink may become clogged. In-between the fins, and all over the fins.
{ The Heatsink absorbs heat. It then radiates the heat way through the Tall, Thin, fins }
When a Processor overheats, (Surpasses it's Thermal Limit), it turns off.
(BIOS turns it off)
This is a fail safe feature built in. Keeps the Processor from burning up.
With the cooling system being clogged, the Processor overheats.
Solution is to clean the laptop THOROUGHLY. I don't believe at this time a can of compressed air for computers, blo-wing air from the outside, will help.
It will just push the 'Gunk' in tighter.
The laptop needs to be disassembled, and thoroughly cleaned out.
It may, or may not need new Thermal Paste for the Processor, and graphics chipset.
(If the laptop has been cleaned recently, and has this problem, it's because the 'tech' probably didn't replace the Thermal Paste.
Thermal Paste will dry up over time, and lose it's thermal conductivity properties )
Do you wish to attempt this cleaning procedure yourself?
If so post back in a Comment, and prepare for a LOT of reading.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-samsung
(The R520 is VERY similar )
http://forum.notebookreview.com/samsung/117192-samsung-x20-cleaning-cooler-fan.html
The above is for a Samsung X20. Posted, because I would like you to look at the last photo on the page. Here you see an average finned Heatsink, and the 'Gunk' it can collect.
Regards,
joecoolvette
Feb 12, 2012 | Samsung R519-53S Notebook
Hi my Samsung R519 keeps locking up after 10 to 15 mins, fan seems to be running OK. Any ideas????.John
try going to the settings on your computer and turn the auto lock off and sleep off.
Aug 10, 2011 | Samsung R519-53S Notebook
Hi i have a samsung r519 and i carnt figure out whats wrong with it i ran out of battery i plugged the charger in but the light on the charger just dimly flashed one of the lights on the laptop flashes but...
check originality of the P.S.U.--check it is the correct item running at the stated values.Check the polarity of your connection,this is printed on the side of some units its like a small ball surrounded by a "C" check you dont have one of those universal P.S.U's which have connectors that have to be correctly connected --look for a small "arrow" on the side of the connection denoting correctly plugged in.
Feb 27, 2011 | Samsung Computers & Internet
Restore factory settings for my samsung r519 laptop win7
system restore can do this for you if windows does work
if not recovery disc are sold on line through ebay and other web sites
Jul 25, 2010 | Samsung N13013B Netbook
Computers & Internet Logo
860 people viewed this question
David Payne
David Payne
