FixYa.com
Tags:
Monitors
Generic problem for all Monitors
Acer AL1715 going on and off (LED blinking)
posted by maxwelleb on May 04, 2008
hi, i have an Acer AL1715.
The power LED goes on, after some seconds it goes off again.
I see the backlight for a short moment trying to go on.
I opened it and see that a capacitor is mechanicaly deformed, it is a 16V (C922).
I disconnected the backlight from the powersuply and plugged the power suply in; then the LED stays green and goes orange because no VGA signal is there.
So i think there is a problem, that the power suply tries to power on the back light, but there is not enough charge on one of the capacitors so it goes off again. But i dont know which capacitor to change.
Before i change all of the capacitors i want to ask you maybe you know the solution.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 05, 2008
Helpful (85)
wolftech
Rank:Master Master
Rating: 81%, 12 votes
Hi maxwell,
Firstly check for the surrounding components like th coupling resistors for a short. Change them, then look for leaky diodes (a diode shows low resistance when connected to a multimeter with correct polarity and MUST show infinite i.e. NO resistance at all when polarity of the meter testprods are reversed) As for the deformed capacitor change it with similar type, voltage and size.
VERY IMPORTANT: Make sure you put in the new one back in the same polarity (since it is an electrolytic type capacitor from what you mentioned in your querry) elase the new one will explode if the polarity is wrong.
Better still, if you are not good at soldering components that are so closely attached on the circuit board, just give it to an authorised service center in your area.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP vs19 (Silver) 19" LCD Monitor HP Compaq FS7600 17 in.CRT Conventional Monitor HP L1702 (Carbonite, Silver) 17" LCD Monitor HP 91 (White) 19" CRT Monitor Sony CPD E200 Monitor Philips 170S4FB (Black) 17" LCD Monitor Philips 170S5FS (Silver) 17" LCD Monitor
Can you Help with these Monitors problems?
Star Logic 17 inch LCD Monitor
i am tryin to coonest
i am tryin to coonest my HP... Answer This...
Monitors
screen on monitor very dark
Do not know how to adjust my... Answer This...
Polyview S17E 17" LCD Flat Panel Display With...
Grey then screen goes blank on...
As soon as I attach the powr is... Answer This...
Toshiba P000232050/F 13.3" LCD Monitor
interference lines and patterns...
I have noticed what seems like... Answer This...
Samsung SyncMaster 204B 20.1" LCD Monitor
monitor
we have had this monitor for a... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
