Question about Whirlpool Washing Machines
Front loading whirlpool stopped part way through wash with a F 21 error message. Please advise. Thanks; Kelly
    Brigadier General:
  • 8,619 Answers
Hi Kelly,
Thanks for using FixYa. Error F21 means long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
What does F- and 21 mean
Error code F 21 means the drain is clogged...follow this advise for the Whirlpool washer as Maytag was bought by them
there is also this site for the washers http://fixedappliance.blogspot.ca/2011/11/whirlpoolkenmoremaytag-more-f02f21-sd.html
Jun 04, 2015 | Maytag EPIC MFW9700S Front Load Washer
Error 21 was on washer, we cleaned out drain then started washer it appeared to be working, but then error message 21 came on again. It is very late so tomorrow morning we will open drain again.
Hello, it can only be dirty filtersomething in the pump drain line blocked up or failed pump. I would check the filter again and if its clean put the drain hose in a bucket see if it drains but chances are you will need a new drain pump. hope this helps please rate my answer thanks
Jun 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I need the operating manual "How to" for the Whirlpool duet washer and dryer.... thank you....
Hi and welcome to FixYa, I am Kelly.
If you would please.... find your model number(s) as there are at least 3 versions of the whirlpool duet. Then you can go to this site:
http://www.whirlpool.com/custserv/index.jsp
and enter your model numbers one at a time where it says Manuals & Literature to down load the manuals.
Thanks for choosing FixYa,
Kelly
May 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Getting an error message on my Whirlpool duet washer - F21
F 21 means slow drain remove lower kick plate couples screws at bottom//you will see the drain pump there is a clean out at the front of pump/ turn that out counter clock wise that is a coin collector but many other objects get in it to/ remove items and reverse to put unit back together....
If I helped you please vote If you need more help please ask good luck
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 21 error message. Not completing wash cycle
f 21 slow drain remove front kick panal//clean out pump..if it helped please vote Good luck need more help please ask....
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool front loading washing machine and when I try to do a load of laundry, it will wash, but then flashes an F21 error message....and stops......I have tried canceling the load and restarting...
The F-21 code is a blocked drain tube. Take off the front lower panel and locate the drain. Should be front right, Disconnect it and clean out the little trap that collects stuff. Put back together and should be fine. I always find stuff like coins and tissues wadded in there. It made for collecting foreign matter to keep the drain clear.
Jan 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
