Question about Ionic Pro (HW-020002) Air Purifier
Why does my ionic pro air purifier make a hissing sound?
SOURCE: Can't clean Ionic Pro CA-500 inside?
This unit is a pain in the @$$ to disassemble but it CAN be done. The way I always look at it: Someone ASSEMBLED it.
Remove the four screws on the bottom stand followed by two screws on the bottom side of the unit. Then remove the tiny little screws up each side that hold the grill together (you will need a precision screwdriver).
Carefully pull apart- don't force it.
One half comes off (clean that half) in bathtub. The other half does not come off-vacuum that half out and use q-tips.
When re-assembling, watch for two things: First the wire cleaner (that slides) runs on a track on each half- pull it out a little to best allow for fitting. Second, there are little tabs at the top that fit under the control panel-watch for those.
email me at originalpairadice@yahoo.com if any problems.
Posted on Dec 23, 2007
SOURCE: blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Posted on Mar 25, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Posted on Jul 13, 2008
  • 13 Answers
SOURCE: Ionic pro problem
Try cleaning the springs the the blades connect to, they're probably making a bad connection due to dirty springs.
Posted on Jul 30, 2008
SOURCE: My.Ionic.Pro.doesn't.Blow!!
The red light means the unit needs to be cleaned. A blue light means the unit is working correctly
Posted on Oct 09, 2008
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
My purifier hisses all the time.
I work for the Ionic Pro Company. Please call customer service at 800-875-8577 and they will do some troubleshooting with you. Thank you, Mary
Dec 25, 2010 | Ionic Pro CA500 Air Purifier
Makes a hissing sound after I clean it
It may be a little late that I am answering your conundrum, but once you clean it, put the unit back together, tip it upside down until you hear a "click" and then turn it on. No hissing :)
Dec 24, 2010 | Sharper Image Ionic Breeze GP (SI730) Air...
My ionic pro turbo air purifier keeps buzzing even after I clean it
Hi lsalazar113
I work for the Ionic Pro company. Make sure you are cleaning the ionizing wire too. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 19, 2010 | Ionic Pro TURBO Air Purifier
Makes hissing sound, then immediately clicks to "clean"
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 28, 2009 | Ionic Pro TURBO Air Purifier
Cleaned the machine. Put the plate back in it hissed like it was dirty for a couple of seconds. All the lights went out and it will not go back on. What do I do?
You still had water in it and the hissing you heard was the water cooking. If it has a fuse, check it. If it doesn't, you probably burned out the control board.
Oct 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Hissing sound intermittent on a ionic pro. hisses on levels low- med,-high.
my ionic hisses after we clean it and won't stop what can i do to stop the hissing?
laurie K
Jan 16, 2009 | Air Purifiers
Ionic Pro (HW-020002) Air Purifier Logo
394 people viewed this question
Top Ionic Pro Air Purifiers Experts
Thomas Perkins
Thomas Perkins
Brett Duxbury
Brett Duxbury
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
