Question about Freezers
There is a drain plug in the bottom of freezer. How do you defrost and not have water on floor. Is there an attachment hose of some kind? I do not have a manual.
    President:
  • 670 Answers
You did not supply a make or model. Typically there is a drain in the freezer with a drain tube to a drain pan below the machine. If you take the bottom grille you should be able to see the drip pan and the drain tube. The drain tube is a flexible tube about 1/4" diameter you might be able to attach an extension using a barbed fitting that you can get a a home depot or lowes.
Posted on Aug 23, 2010
Model # FUF17DACWH Freezer is leaking water
After the defrost mode, the water from the melted frost or ice should go down the drain at the bottom back of the freezer compartment. That drain is probably plugged with some gooey gunk. If its an upright freezer, there will be a hose clamped to the back that comes out of a plastic fitting.. detach it there and 'fish' into the plastic fitting with a short piece of wire then blow into it to dislodge whatever may be there. Blow downward on the hose as it too could (probably not) be plugged between there and the drain pan under the bottom of the refrigerator.
Severe cases require that the freezer back be removed and the drain thoroughly cleaned. That gets real tricky, but its doable. Ice makers in the way complicate the process too.
Jun 14, 2014 | GE 16.7 cu. ft. / 473 liter Upright...
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
Quick upright defrosting
Good day,
The aerosols help. But, hurry up with any type of refrigeration equipment is many times a quick way to disaster.
Go slow and thorough. A little lost food is far better than a messed up machine.
Patience is your friend here.
Apr 30, 2010 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Frost free freezer forming layer of clear ice on floor of freezer
This sounds like clogged drain / hose in the freezer compartment, here's why:
When the defrost circuit turns on, the compressor turns off. The defrost coil melts frost that collects on the freezer coil and drips in to a small pan located below the coil. The pan is formed so that the water that drips in it can flow to a hose connected under it. When the defrost cycle completes. the compressor runs again, bringing the temperature in the freezer to about 0 again. Any water remaining anywhere in the freezer will turn to ice very quickly.
If the hose should become clogged with ice, or slowed by mold, bacteria, etc. - water flow will be slowed, and / or eventually stopped. Ice will become thicker and thicker on the floor of the freezer as there is no place for the water to go.
A service manual for the appliance would be a good idea, but may not be required. You'll need to unplug the freezer and empty the contents. Defrost manually with a hair dryer or other heat source. If you decide to chip away ice, do so carefully.
The defrost and drain area of most refrigerator / freezers are located behind the rear panel of the freezer compartment. This is where the manual would indicate where the parts are located. Remove any ice maker installed if needed to remove the back panel.
Defrost any ice previously hidden by the panel. Chipping ice here should be a last resort, as sharp edges can damage cooling coils, tubing and the drip pan itself. Use a turkey baster filled with hot water to direct a stream at the area of the pan filled with ice. Hot water will likely have to be directed down the opening on the pan to melt ice in the hose as well.
Once the ice is cleared, mix about a 10% to 20% solution of bleach and water (1/2 ounce bleach to 3 ounces water) and direct down the drain hose. This will kill and inhibit further growth of mold and bacteria in the hose, which should help it drain water quickly.
Re-assemble and plug into power.
I hope you found this Very Helpful. If you need more help, ask again - but include the freezer manufacturer's name and model number. Good luck!
Dec 03, 2009 | Freezers
Water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Jan 30, 2009 | Frigidaire 16.7 cu. ft. / 473 liter...
Maytag side by side freezer leaking water and icing in bottom
Defrost drain system is plugged and not draining out the back and into the drain collector. There is normally an air trap in this drain line under the back and behind a fiber removable panel. Check this trap and make sure it is clear of any blockage. You will then have to defrost the freezer and clear out the ice. Don't forget to replace the back fiber panel.
May 17, 2008 | Freezers
Freezers Logo
113 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
