Question about Craftsman Garden
We have a craftsman 15.5 hp motor. It keeps blowing fuses. What is causing this? We have changed the spark plug, checked the battery, checked starter, put in a 30amp fuse. It turned over then blowed this fuse.
  • 66 Answers
SOURCE: 30AMP FUSE KEEPS BLOWING WHEN I CONNECT THE BATTERY
i have had that happen when i accidentally hooked cables backwards to battery.red cable(pos) to post w/ + next to it & black cable(neg) to post w/ _ next to it is correct.
Posted on Feb 16, 2009
redbeard00
  • 957 Answers
SOURCE: starter fuse keeps blowing
Sounds like a short in the system. you will need to inspect the wiring and posably, bench test the starter. Check the cables to the battery. Make sure the wires and the battery are in good shape.
Posted on May 13, 2009
jasperoni
  • 203 Answers
SOURCE: starter enabler fuse blows which means the starter motor does not work until fuse is changed
It is possible that the starer is pulling too much amperage- 1st thing you need to do is find out what if any other consumers are on that circuit, 2nd you need to find out how much amperage is being consumed by the starter. 3rd test you wires most likely if a wire problem it is the heavy hot wire on the starter or the back of the alternator has a loose retaining nut
Posted on Jun 01, 2009
darjr
  • 378 Answers
SOURCE: starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
The fuse is always blown due to overload fuse, check the rating of fuse is it the same as the original fuse?.
  • 106 Answers
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
Kohler 15 hp motor turns over but will not run.what is wrong?
take the spark plug out and turn the engine over to blow out any excess gas in the chamber. put in a new spark plug and try again. if this don't work you may have a valve or timing problem. there are many videos that show how to check valve clearance and flywheel key on you tube. if you have gas and spark and compression it should start.
Mar 31, 2018 | HP Garden
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fuses location for craftsman 26 hp 54" deck mower
Replace start fuse on right side of motor by oil drain plug.
May 04, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
99 vw jettal 2.0 gas fuse 29 15amp fuse keeps blowing-no spark unpluged coil and fuse keeps blowing. help please
Thats the fuse for the ECU, engine control module, and is a 15amp for gas 2.0. i would locate the ECU which is under the center of the plenum in the engine compartment and disconnect the long plug. Check for green discoloration on the multipin connector. Sometimes moisture will get in there and short some of the pins together. Leave ECU unplugged and replace the fuse. If it still blows cause is between the fuse and the ECU.
Dec 27, 2010 | 1999 Volkswagen Jetta
I have a 24in snowblower with electric start a year old and cant start it manually or electric
Did you drain last years fuel out completely? That is usually the problem with small engines. Gasoloine has a shelf life of thirty days and then it starts to turn to varnish. When that happens everythinh in the fuel system gets coated. The carb will not work if it did start. If you did clean and blow out fuel before storage then check for spark. Pull the spark plug and keep it connected to the cable then fasten it somehow to the engine block (Vise-grips). Crank the motor and you should see spark on the plug. All this assuming your battery is good. Did it sit all summer in the heat? Have it checked for cranking amps and voltage. No spark means no ignition system. Spark but no start is fuel system but battery must be 100% before anything else.
Dec 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blowing a 25 amp fuse, will not start
have you checked all the wiring. A wire may have burned up and is arking and causing the fuse to blow. That has happend to me. hope this helps.
Apr 21, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1993 Yardman riding mower - motor won't turn over
Yes there is. I don't know from your description whether or not this has a
OHV engine. but if it does this is a common problem. over time the valves
get out of adjustment. thus causing hard starting. the valve lash will have to be adjusted to specs. what happens is the (ACR) automatic compression
release fails to open the exhaust enough thus causing hard starting.
and it kills batteries and starter gear teeth.
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
55 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
