Question about Kenmore Dryers
Power went out and dryer is blinking "pf" and no buttons work
    President:
  • 1,554 Answers
It blinks "PF" to indicate that the cycle is interrupted due to a power failure. Press Start to continue the cycle or press Stop/Cancel to clear the display then restart the cycle.
Unplug the dryer for at least 30 minutes to forcibly reset the control if the display does not clear out or if the dryer cannot be restarted. Indicate the complete and exact model number of the dryer for further and specific troubleshooting repair advice.
Posted on Aug 23, 2010
I have a Maytag dryer model: MEDE300VW0 that is showing a PF code. I have tried unplugging, pressing the cancel button, etc. as recommended on various internet sites. PF code persists.
i know that the voltage overseas is different form the usa,that's telling you there was a power failure while the dryer was running,check the back of dryer to make sure you have 240 volts going to the dryer,you could have a bad power cord or something to do with power source.
Feb 06, 2018 | Maytag Dryers
What causes maytag neptune dryer has pf error? My dryer worked in air fluff but not sensor or timer mode. Now it will not work at all. the lights on the control panel just blink . What could be the cause..
Pf shows a power failure hols the stop clear button and it should work again.As for your other problems I will more details such as a model number Gas or Electric dryer and example of the problem in detail
Aug 05, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Machine flashes PF and we tryed holding the start
PF is power failure. Push the cancel/clear button to clear this out
Mar 12, 2010 | Whirlpool GEW9200L Electric Dryer
DISPLAY SAYS "PF"
HI, there may have been a power surge that shut this unit down or, the junction box may be shorting the power sector. this will damage the main control in this case. i recommend shutting the power off by, pulling the unit plug from the wall socket or, shut the circuit breaker off. let the unit sit for 5 minutes without any power. this will reset the logic chip.
Power the unit back up after this 5 minute wait to see if the reset worked. if the PF is still present, this will confirm a main control fault. replace the control in this case.
**check the power cord junction point for worn connections.
Jul 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The dryer will not turn on its flashing pf
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Apr 15, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool gas dryer doesn't run. error code pf shows on lcd
pf usually means power failure. Try to clear the screen or hit the off button to clear pf and then see if it works.
Nov 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Error PF
PF simply means power failure, not really a fault as much as a visual indicator to let you know that you've experienced one. i would check your electrical outlet,sounds like a loose connection
Mar 04, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Neptune dryer will not work
PF= Power failure hit the cancel button and it should clear then you will be able to select a cycle. Let me know
Jan 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
PF indication (Power Failure) and dryer digital light up but will not start
check your owners manual for clearing error codes in trouble shooting on theese electronic models lots of time you have to clear the codes to go back to normal ops by pushing certian buttons on kenmore i dont know which ones they are usaly its clear/cancel buttion some times you have to holld them so many seconds just unplugging it will make it think it has another power failure
Dec 26, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
102 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
