Question about HP Compaq d530 SFF PC Desktop
HOW YO OPEN THE CASE - HP Compaq d530 SFF PC Desktop
  • 105 Answers
Adjusted larger screw in bobbin case. did the yo-yo test, it did not make a difference in tension. Rethreaded the thread on top. I still have the bottom stich loose with little dots on a line.
raise the needle thread tension as it is the controlling tension when sewing
the tread tension is the screw which holds te spring plate in position under which you pull the thread after installing the bobbin into the holder
Feb 21, 2017 | Sewing Machines
Bobbin tention
general guide - full bobbin if threaded into the bobbin case , there is a small screw on the spring - the correct tension is - when whole bobbin case with bobbin inside - being held by thread (like yo-yo) and the lot should drop just a fraction when jerked down-up a little. Then match the top thread tension.
Nov 06, 2015 | Sewing Machines
LG microwave oven does not heat up
Open it and check its fuses forcontuinity using amultimetter in ohms if there are fine check yo capacitor if its fine check yo magnetron check the magnetron with ameter it must give 0,2ohms if i5s fine but ithink its yo fuses
Sep 14, 2014 | Microwave Ovens
How can I now if the thermostat is not working
RUN YO CAR TIL TEMPERATURE AT HALF OPEN YO BONNET CHECK YO TOP PIPE FRM THE RADIATOR AND THE BOTTOM PIPE FEEL IF THE TEMPERATURE IS ALMOST THE SAME IF THE OTHER IS HOT AND ONE IS COLD YO THERMOSTAT IS NT WRKING
Sep 09, 2013 | Honda Civic Cars & Trucks
How to connect samsung gt c3200 to pc through bluetooth
yu need to install samsung pc suite on yo pc , when yu open the pc suite it will ask you the method yu want to use to connet yo 4ne ,cable or bluetooth.if yo pc don"t have blue tooth yu can buy a blue tooth dongle
Mar 20, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Once i put on the copier then started worming up after sometimes then error code come out "SC304" turn off the power and put it on again if the message come again call service
look my friend that messege mean pcr primary charge roller defective some times it's works but don't give charge to drum unit when yo opend drum unit look it behind drum unit yo will see solid shaft if yo look back open back cover and take off alot of thing to reach to solid shaft from behind yo will see that spring have on it big pressure and if yo pull to get normal position it will works already just close machine and opend
Feb 16, 2011 | Ricoh Office Equipment & Supplies
How to clean scraper blade
first open drum unit put out screw tapping correctly and not be nerveous on it there is part catch drum may be brocken while yo open it and yo will see pcr and drum and scraber withe piece of clothe moistured with water little little water
Jan 29, 2011 | Ricoh Aficio 1013F Copier
Cd rom
Go into the computers bios at startup .
is the cd rom drive enabled and detected .
if not then open the case and check the cables to cd
Jan 09, 2008 | Compaq (120192-B21) CD-ROM Drive
AEG dishwasher not heating
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Aug 19, 2007 | AEG 23 in. Favorit 86070Vi Built-In...
HP Compaq d530 SFF PC Desktop Logo
87 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
