Question about Dell Inspiron 2200 Notebook
Cd drive doesn't read disks - Dell Inspiron 2200 Notebook
  • 2,567 Answers
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD driv.
Posted on Aug 23, 2010
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
Sep 22, 2012 | HP Pavilion dv6775us Notebook
My dvd drive doesn't work
If it happens for only one particular disk:
Bring that disk to a game store like Gamestop or Rock30 Games and have them professionally clean the disk for a couple bucks.
If it happens for all disks:
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Jul 31, 2012 | Acer Aspire 5738Z Drivers Recovery Restore...
Toshiba satellite l505-s6946 not reading disks
Jun 30, 2012 | Toshiba Computers & Internet
Computer is not reading the installation disk
By installation Disk do you mean the CD/DVD-ROM? If yes
Check to see if the drive's LED flashes when the system is trying to boot. If it doesn't, open the system and make sure all the cables to the CD/DVD- ROM is properly connected and to the right slots. If the cables are properly connect and the CD/DVD- ROM is still not working replace the CD/DVD-ROM.
However, if its that the system could not install a particular program, make sure the installation files are complete and try again. If its a downloaded program, verify the completeness of the file downloaded and try reinstalling the program.
Feb 13, 2012 | Peachtree Software Computers & Internet
My cd and dvd player is not working. i have a toshiba laptop with windows vista. please advise. thank you.
If by not working you mean that the drive physically works fine, will eject and stays closed when you put a disk in, but does not read the disk or gives errors when it tries, then a simple cleaning could be enough to revive it. A lens cleaning cd is easy enough to find at any local department store and running this in the drive should take care of any problems reading disks unless the disks themselves are damaged.
If however you meant that the drive doesn't respond to eject requests, either when pressing the button, or choosing "eject" in windows, then the hardware itself is at fault and will need to be replaced. The drive is easy to swap out with a replacement or you could even get a portable external drive and only connect it when you actually need to use the disk. Also if the cleaning suggested above doesn't help, and you are sure the disks you are trying are not dirty or scratched to heavily on the bottom, then a replacement drive would also be in order.
Sep 07, 2011 | Microsoft Windows Vista Ultimate Edition
My CD/DVD drive is not reading Rosetta Stone - Espanol Edition. It stars and spins, but then stops. OS: Vista SP2 Disk Drive: Unknown RAM: 3 GB - DDR2
Try playing a music CD to see if it works. Then try playing a DVD ( a DVD movie ) and see if that works. If the CD works and the DVD doesn't then your CD/DVD drive is probably the problem and needs to be replaced.
Jun 24, 2011 | Dell XPS 410 PC Desktop
CD ROM
The drive has NOT been able to read the directory of the disk you put in.
Possible causes:
Disk may be a DVD which your drive may not be able to read.
Disk may be a DL DVD (double layer) whcih your drive may not be able to read.
The disk might be a BluRay which your drive may not be able to read.
Your drive may be defective or have a dirty read head.
May 03, 2010 | Compaq (120192-B21) CD-ROM Drive
I cannot open cd's on my emachine 4260. Can you help? The discs have data on them (Knitting patterns)
It could be a proiblem with the cd-rom drive or the computer. You can try and run a cd lens cleaning kit in the drive to try and clean the lens. Also try using a different SATA or ATA cable for the drive depending on which one it has(the cable could be bad). I would take out the cd-rom drive and try installing it into another computer to verify if the drive is working. If the drive acts the same in a different computer then replace the drive. If it does not then there might be a hardware problem with the e-machine motherboard.
Nov 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
My cd rom work properly but can't read compact disc
try a cleaning disk .. thats a CD wiht little brushes mounted on it such that it brushes off any dust accumulation on the laser .. you just put the disk in and let it run a short time .. the cleaning disks are available most places for $4 to $8 . i have seen them at the dollar store also .. if that doesn work then a manual cleaning of the laser might be required . (you have to take the drive out and remove its covers .. thats a job for the pros .. you can replace the whole drive for a very low price anymore .. around here a CD drive that also does DVDs and can even burn DVDs and CD is only $24 . maybe less if you are only interested in a CD only drive .. its usually easy to change the CD drive .. just put any jumpers on the same pins as the old one .. if you system is more that a couple years old then you likely have a PATA type drive .. newer stuff might have the SATA connectors ...
Nov 06, 2009 | Computers & Internet
My acer aspire 8930g wont let me do a factory backup
Go into the BIOS setup screen and make sure that the CD loads first. IF that doesn not work to read the disk then :
Download :SeaTools" and burn to a CD. Check the Hard disk drive with the CD.
http://www.seagate.com/www/en-us/support/downloads/
Jan 24, 2009 | Computers & Internet
Dell Inspiron 2200 Notebook Logo
32 people viewed this question
Alun Cox
