Question about JAKKS Pacific Jakks Eyeclops Bionicam Video Microscope Eye Clops
Replacement usb for eyeclops bionicam - JAKKS Pacific Jakks Eyeclops Bionicam Video Microscope Eye Clops
I think that the led light burned out
You do know the lamp won't light unless the projector has an input source connected?
It's not designed to be repaired because there are safety issues in case you put too bright a lamp in, after all it is a children's toy. That said you have 2 options, take out the old lamp, and identify it, that should be fairly easy, or contact the distributors.
Contact JAKKS
Jun 16, 2014 | JAKKS Pacific EyeClops® Mini Projector
Vox mini led projector light blinking problem
I dont think it as solution. when power on, it has to show the VOX logo initially. Later we can set the i/p mode...
I had the problem with my new led vox projector. Larer I replaced it. now I got the same issue with the replaced product. Each time I used only 2 to 3 hrs the device. Waste of buying such brands.
Jul 28, 2013 | JAKKS Pacific Eyeclops Bionic Eye Tv...
Do you have to replace the mother board for USB replacements
Hello, yes you are right for that USB replacement you need to replace the motherboard, as USB port is Onboard.
Cheaper solution... there are adapters available that can convert your serial port to USB. Then purchase a 4 (or more) USB hub, to plug into that.
Apr 15, 2010 | Toshiba Satellite A215-S7422 Notebook
Can i connect the eyeclops to a laptop?
Yes you can. If you have composite video out. Composite video is the Yellow connector like you see on TV's, DVD's, VCR's, and other items. It uses a standard RCA connector.
If your laptop doesn't have a composite out you can purchase an adapter that will supply this. These adapters are usually connect to your USB port.
Feb 19, 2010 | JAKKS Pacific Eyeclops Bionic Eye Tv...
Problem with eyeclops video projector...after
unplug all rca cables from your eyeclops, then try all three colors one at a time, into the yellow colored hole on the side of your eyeclops, until you get a picture, and you have to have the dvd player on and playing a dvd, otherwise the light won't come on your projector, then plug in the audio sources, the yellow and white. When I got my eyeclops mini projector, it wouldn't work at all when I plugged the yellow rca cable in the yellow hole on the side of the eyeclops, the red into the red, and the white into white. Only when I placed the red rca cable into the yellow hole on the eyeclops, the yellow into the red hole, and the white rca cable into the white hole did it finally work. That was for my dvd player. With the video game function, I plugged each color Rca cable into their same colored holes on the eyeclops and it worked fine, but again, you have to have your device, whether it be a dvd player or game system on and running before your eyeclops led lights will turn on. Not sure I had to switch colors when I played my dvd player, but that's how it works on my mini projector, anyways.
Jan 17, 2010 | JAKKS Pacific Eyeclops Bionic Eye Tv...
Light doesnt come on at all
i am having the same problem. did you ever figure it out?
Jan 13, 2010 | Zoom EyeClops Bionic Eye Multi- TV...
JAKKS Pacific Jakks Eyeclops Bionicam Video Microscope Eye Clops Logo
59 people viewed this question
Top JAKKS Pacific Toys Experts
Andrew Taylor
Andrew Taylor
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
