Question about Whirlpool Accubake SF362LXTS Kitchen Range
How to light pilot light for whirlpool accubake oven\
3 Suggested Answers
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
Posted on Jul 11, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Dec 28, 2009
Testimonial: "Thank you so much. This is a job that my husband can do to fix it."
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Is there any kind of pilot light that I need to light? I just had the gas turned and none of the burners will light and the oven won't get hot.
There may be a gas shutoff on the range gas supply. If so,turn it on.
If it is already on,turn on a surface burner and use a match ti light it.
It will take several minutes for the air to purge from a system once gas supply has been restored.
Aug 03, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
I have a whirlpool gold self-cleaning oven accubake system super capacity 465. The oven will not get worm. The burners work just fine. The oven runs thought it pre heat time but never gets worm.
While I can't solve your problem, I can say, you are not alone. I own this oven and have been having major issues with it, I have had service men out to my house 3 times and still it isn't fixed. We were told that this particular oven is an experimental unit...it only has 4 working parts. The pilot/ignitor for the burners AND unit are the same, so if burners work it has nothing to do with your pilot light or ignitor. More than likely it is the thermostat OR the motherboard. Thankfully we have home owners insurance and have only had to pay $60 to get them to come and fix it. If you are not so lucky you may just want to call Whirlpool, give them a piece of your mind and then go buy a different brand oven.
Jan 15, 2011 | Ovens
The oven doesn't work
unplg the system for 15 minutes then plug it back it. When you plug it back in make sure everything goes in straight. this is just trying to reset the system
Jan 02, 2010 | Whirlpool Accubake RF362LXTS Electric...
Whirlpool accubake doesn't preheat properly
Are both of your heating elements lighting up when you are preheating? It sounds like the oven thinks it is pumping power into both elements and one isn't working. Oven elements are generally easy to remove and replace!
Jan 08, 2018 | Whirlpool Kitchen Ranges
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Accubake SF362LXTS Kitchen Range Logo
1,194 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
