Question about Rockford Fosgate Power 1000BD Car Audio Amplifier
My rockford power 1000bd is not pushing my sub at all. though the badge light comes on and rca input and out put work there is no response from the subs when hooked up. the amp stays on and does not show any signs of damage nor does it smell or look burnt when i took off the panel on bottom. i did not pull the circuit boards from the anti corrosive grease at all but am thinking about it. looking for some good advice to keep my oldschool amp running my hx2. thanks
5 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
Posted on Sep 10, 2007
etirbynnor
  • 655 Answers
SOURCE: Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Posted on Apr 27, 2009
spoopavitch
  • 40 Answers
SOURCE: how can I get rid if whining noise comming from
wrap a striped wire figure 8 style around the output rva jacks on the back of your head unit
Posted on Apr 03, 2010
evan89
  • 356 Answers
SOURCE: do you know where I can fix my Rockford Fosgate
You could open it up and if you are familiar with soldering that is most likely your problem something that was soldered down has come loose.
Posted on Mar 03, 2011
I just installed a new xo vision x349nt dvd receiver in my car . My rockford fosgate p3001 amp turns on but the subs doesnt come on but when i would take the base control out and put it back in i can hear...
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
May 18, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
It started cutting in & out, now i can barely hear the subs.
It sounds like the amp is having problems internally. You should contact Rockford to find a place that can fix it.
Apr 21, 2011 | Rockford Fosgate Power 1000BD Car Audio...
Do you know where I can fix my Rockford Fosgate Power 1000BD Car Audio Amplifier inside tucson? what could be the best choice? fix it ? or sellin it?
Mar 03, 2011 | Rockford Fosgate Power 1000BD Car Audio...
Lights up no sound
Disconnect your subwoofer wiring from the Amplifier, and use a multi-meter to check for resistance, or an open line. The subwoofer should have resistance. If not, check the wiring inside your box. If the wiring checks out, replace the subwoofer. Also, check your RCA connection from the Head unit to the Amp.
Jan 17, 2011 | Rockford Fosgate Power 1000BD Car Audio...
How can I get rid if whining noise comming from inside of my rockford fosgate 1000bd
Apr 03, 2010 | Rockford Fosgate Power 1000BD Car Audio...
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Rockford Fosgate T15004 The Amp still powers up with the
Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
Oct 27, 2009 | Rockford Fosgate T15004 Car Audio...
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
Only thermal light on.
check rca and make sure u have right input to amp and speaker
Apr 12, 2009 | Rockford Fosgate Power T3002 Car Audio...
Amp Issues
1800W peak output at 2 ohms
975W peak output at 4 ohms
600W RMS (continuous) at 2 ohms
325W RMS (continuous) at 4 ohms
Variable LP crossover adjustable 35-250Hz
4 AWG power/ground inputs and RCA pass through
Low-pass filter
Bass boost 0-18dB adjustable remote punch bass EQ
Signal-to-noise ratio: >80dB
Line-level input
It is going into protect mode for a reason.
Disconnect the subs and turn everything on again. If the light comes on, the problem is internal and will need servicing by a technician.
Dec 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Rockford Fosgate Power 1000BD Car Audio Amplifier Logo
104 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
