Question about Belkin ExpressBus (F5U021) 4-Port USB Hub
I installed a 4 port hub to speed up my file tranfer to a flash drive. The files transfer but not any faster then using the front usb ports. It is normal?
    Brigadier General:
  • 10,406 Answers
Yes. While the speed from the USB device to the USB hub may be faster (USB 2.0 protocol, rather than the slower USB 1.1 protocol), your hub is still connected to a USB 1.1 port on your computer.
Posted on Aug 22, 2010
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 | Computers & Internet
Dont know how to tranfer from pc to sandisk
Go to My computer and it should say something like Removable disk ( :h) , click onto it and thats whats inside ur USB, to transfer copy and paste the folders or just Move then to your removable disk
hoped this helped :)
Mar 18, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
I have a PNY 4GB high speed USB Drive. I want to
Well, the easy way would be to do this
But if you want to use the USB drive just insert it into an open USB port
  1. click Start
  2. click My Computer
  3. Select the USB drive from the list of connected drives
  4. Click and drag the files from their location to the USB drive
To get them to the other computer follow steps 1-3, then click and drag them from the USB drive to their new location.
Sep 16, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Files copied cannot be seen when connected to other systems
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer. (this has nothing to do with electrical arcing)
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
If none of the above steps help look at updating the drivers from the manufacturers web site in the
Aug 03, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Trying to trainsfer program from my computer to the tevion memory
Place the flash drive (mem stick) into the USB port of the computer. Copy the files to it. Remove it from the computer and put it into the USB port of the other computer. Copy the files from the flash drive to the computer hard drive.
The memorystick (flash drive) will show up as another disk in File Manager/Windows Explorer, and disappear when the device is removed.
You cannot transfer already installed games from computer to computer, only the files. The game must be installed from the original CDs in order to function.
You can transfer documents, music, pictures, etc.
Jun 12, 2009 | Computers & Internet
PNY Optima Pro Attache 4 G
Make sure you are using the right port. There are slow and faster ports on a laptop.. So try plugging it into another and see if it helps
Jul 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Computer freeze on saving files to USB 2.0 External Hard Drive (and USB2 flash drive)
Suggest you look at the motherboard book to check if or how many USB connections are in fact USB 2 compatible. Most modern Motherboards only have 2 USB 2.0 Compatible connections, most are 3.0 or 4.0 compatible. Hope this helps, Malcolm Campbell.
Mar 12, 2017 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
No usb port found
If you can't find such on your machine, then it's either disabled, the BIOS is out of date, the OS doesn't support your USB (Examples abound!) or other. I cut my time loss by adding an USB PCI card.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Belkin ExpressBus (F5U021) 4-Port USB Hub Logo
225 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
