Question about Toshiba Satellite A60 Notebook
Wi-fi ability lost with RAM upgrade
I had Best Buy upgrading the RAM in my Toshiba A135-S2386. They removed the 512MB card and replaced it with 2 x 1GB cards. When I came home and wanted to connect to my home wireless there was no way for me to do so. When I try create a wireless connection it only gives me three dial-up options.
Vagnaskjaer@yahoo.com
    Brigadier General:
  • 6,966 Answers
It is possible that the WiFi card was dislodged or inadvertently snap out of position. Should you venture on a DIY, pls remove the bottom panel covering the memory and/or add-on cards. The WiFi card would be the one with one or two black or gray small cable/wire with connectors at the end. Unsnap the said WiFi card, partially remove/pull from the slot, re-insert and snap back. It may be necessary to wiggle a little bit to ensure that the pins are in contact with the corresponding slot pins. Thereafter, close the lid/panel cover and reboot the laptop.
Should problem persist, you may need to return the unit to whoever replaced the memory and present your concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
My 3 yr old Toshiba - A135-S2386 - Vista - has
Just a suggestion................I have seen the RAM cause these problems in many laptops try your old RAM that came with it see if the problems persist....Good Luck
Jul 23, 2010 | Toshiba Satellite A135-S2386 Notebook
Blank screen asking for password
I presume this is the CMOS or BIOS password.
Turn the unit over and find the ram cover, remove the ram locate the two brass bars near where the ram was. Take a paper clip and bridge them to short out and reset bios password.
replace ram and turn on
please rate our help to keep the FREE service online
Aug 27, 2009 | Toshiba Satellite A135-S2386 Notebook...
General Hardware Question
What is your question? No, these components are not integrated, but everything is attached. If this person cannot find this out for you, do not trust him to upgrade it.
Apr 01, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba laptop problem
The right memory for your laptop is
256MB Memory (PC2-4200) KTT533D2/256, PA3389U-2M25 KTOS534
512MB Memory (PC2-4200) KTT533D2/512, PA3412U-1M51, PA3412U-2M51 KTOS535
1GB Memory (PC2-4200) KTT533D2/1G, PA3411U-2M1G KTOS536
Using the wrong memory can caused motherboard failure.
Try reinserting the old one memory module.
Be sure that the memory is placed in the right way
Nov 06, 2008 | Toshiba Satellite A135-S2386 Notebook
I cannot access my laptop (toshiba satellite A135-S2386...
welcome to fixya
If it is a default password try "admin" as the pass with out the ""
this should work
if it does not please let me know thank you have a good day
Jul 19, 2008 | Toshiba Satellite A135-S2386 Notebook
1024 RAM
You will need to remove the 2-512MB ram that are installed on your computer and buy 2-1GB sticks. There is no other way around this. Download CPU-Z program to find exact memory module needed before you buy the wrong one. Good luck.
May 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Upgrading Ram on my Toshiba A135 S2386 Laptop, still under warrantly
Hi there. There are 2 locations on the border of the plastic cover, both on the same side. You need to use a small flat screwdriver or your nail, and lift the cover using those 2 spots. It will snap out of place ! If you hold the laptop upside down, the front of the laptop closest to you, the 2 places where u need to lift are on the right side. You need to lift on that side, and the plastic latches are on the left side only. Hope you see what i mean ! But basically, lift right side. Thanks ! cheebster.
Jul 09, 2007 | Toshiba Satellite A135-S2386 Notebook
E740 BT can be upgrade to Pocket PC 2003 ?
Sorry but I think that you must choose worst scenario. You should buy “SD Wi-Fi Card”.
Sep 08, 2005 | Toshiba e740 Pocket PC
Toshiba Satellite A60 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
