Question about Canon Office Equipment & Supplies
Canon gp225 with error code e0007-01 reset it but came back again
  • Canon Expert
  • 1,326 Answers
I'm not sure what a gp225 is, but the error code E007 deals with the fusing unit. It means that the fuser film can not find Home Postion. Basicly the film has moved out of place or the film is damaged and moved out of hp. Basicly,to solve the problem the fuser film needs to be replaced. Good Luck
Posted on Aug 23, 2010
  • 1,218 Answers
The fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
Posted on Oct 20, 2010
Canon gp225 erorra cord e 810
*28* reset error check the main board
Feb 20, 2013 | Canon Office Equipment & Supplies
My copier GP225 is showing code error E202
This looks like the American GP-200 copier. You have an error for the Scanner not going back into the home position after it has started to move. This could be the home position sensor, Scanner motor, or the DC Controller Circuit Board.
Jun 16, 2011 | Office Equipment & Supplies
Error code E000 for canon gp225
You can try in the service mode.
Function > clear > error then switch off & on again.
E000 is a fuser error, if it comes back again after you have cleared it a new fuser is required.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | Office Equipment & Supplies
What is the reset for error code E000004-0010?
This is fixing error code. The E004 is heater has failed - this usually last the life of the copier. The 0010 part is that the copier was turned off without resetting the error not a problem to reset. After resetting the error, fire up the copier and write down the error as displayed if it comes back. The sub code is very important to correct the problem. Some codes mean you have to replace the fixing heater power supply or the DC Controller. This is how you reset the code: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Press copier, function ( across the top of display ), CLEAR, ERR, then OK. Turn off copier and power back up. If the error happens again you may have a major problem that a tech may have to resolve. Good Luck.
Nov 02, 2010 | Canon imageRUNNER 5570 Copier
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Apr 17, 2008 | Canon imageRUNNER 5570 Copier
Canon gp225 showing error e803
What error code is showing on the display sceen " Exxxx" it could be a bad laser unit or a bad polygon mirror ass'y.
Jan 29, 2008 | Canon imageRUNNER 8500 Copier
390 people viewed this question
old marine
old marine
