Question about Zanussi ZWF1440 Front Load Washer
Washing Tabs Every time I use my Zanussi it spits the washing tabs into the front door unit which is above the water level. However when the rinse cycle starts the water level does reach them. I have tried putting the tabs on top and in the centre of the load to no avail. Question is how do I stop the machine spitting the tabs into the door area.
  • DiscoDriver May 30, 2008
    That makes perfect sense. thanks
    Hugh
  • 4 Answers
Hi Zanussi do not recommend tablets for this machine as it is a jet system and uses far less water than conventional machines. it recommends liquids or loose powder to be used in the tray I know as I sold these for 10 years.
Posted on May 30, 2008
AEG 50879
This option can be selected by pressing the corresponding button, and remains in memory until the same
button is pressed again. This option modifies the phases of the programme in order to optimize performance
when "3 in 1, 5 in 1, 7 in 1, ......." detergent tablets are used:
- variation of the duration of the programme and the temperatures required to dissolve the detergent tablets.
- reduction of water exchange
- exclusion of introduction of rinse-aid
- exclusion of regeneration
If you use a dishwasher in the traditional manner (detergent, rinse aid, salt) then the Multitab function is disabled. If you use tabs that are already on the market with rinse aid and salt there is a possibility during washing cycle to add a double dose of rinse aid. From rinse aid dispenser and rinse aid from tabs. This will lead to poor cleaning results, glasses will look like they have been washed in milk..To avoid that you must turn on "Multitab" function and thus exclusion of introduction of rinse-aid from rinse aid dispenser. This function also stops the regeneration and will not spend salt because salt is already in a tabs. Also extends the washing time because tablets need more time to dissolve in relation to the traditional powder detergent.
Dado
Jul 15, 2014 | AEG Dishwashers
Washing machine fs1255w does not respond to the programme switch. the end light flashes 9 times, every time
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 07, 2008 | Zanussi Washing Machines
Door remains locked and machine doesn't start running
Did you check and see if the child lock is active?
Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
Zanussi IZ161W Front Load Washer Can you supply this from hot water feed rather than cold water outlet? I intend to use a heat pump which will generate hot water to 40-50DegC cheaply and the HW cylinder...
Not adviseable as you will be rinsing the clothes in hot water as opposed to cold, this could cause problems such as shrinkage depending upon what you are washing at the time.
Dec 09, 2010 | Zanussi IZ161W Front Load Washer
When the washing has done with the fanal spin the machine does not go to door open and we cannot open the door
hi the door lock will open providing the water is below a max level. Drum temp is lower than 40 degrees. drum has to stationery. blockages in the draining can cause some water retention to stop unlocking of the door also can retain hot water from the wash with possibility of higher than 40c temp at the end. you should here 2 clicks at the end to unlock the door if the machine is switched off it will unlock after 4 min by a failsafe device. Occaisionally i have known the machine to have hot and cold water pipes reversed causing all the rinses to be in hot water this would also stop the door opening. finally the door lock can be faulty or wiring to itand rarer the electronic itself.hope this helps
Nov 20, 2010 | Zanussi FJS1225W Front Load Washer
Soapbubbles remain after washing multiple times
The bubbles are probably caused by too much rinse aid. If using 2 /3 /4 in 1 tabs do not fill rinse aid dispenser and turn it's dose level to 1. Make sure rinse aid cover is not open /broken and seals o.k. It's also important to check cold water is fed to the appliance and also it does some hot washes... not all at 40c. as rinse aid will stick to inside of case if machine never does a long hot wash.
May 16, 2010 | Bosch 24 in. SHE66C05UC Stainless Steel...
Gunge is accumulating around rubber ring at door of machine
Clean with a mixture of baking soda and detergent in hot water, rinse and dry. Leave the door ajar after each wash so that the interior will dry. Front loaders have no venting.
Sep 30, 2009 | Zanussi IZ12 Front Load Washer
ZANUSSI ZWD162701 washing always comes out cold - WHY?
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Zanussi ZWD1270 Front Load Washer / Dryer
Water levels
Probably the nivauchamber is clogged of lime or something. Or you are overloading the machine
Jan 31, 2008 | Zanussi ZWC1300W Front Load Washer
White film on dishes
Experience : 30 years in dish washing as a professional instructing hospitals and restaurants.
It is not necesaasry to cover the heating element as long as sufficient water is present so as to not STARVE the water pump.
Listen to the sound of water serging with the machien running. If it is contant you have enough water if the sound comes and goes then the pump is serging . either lyou have a low water level or CLOGGED strainer in the bottom of the machine (inside).
you might also open the door real fast during the wash and check for water splashing and flows---- you might get wet but this way works .(wear protective eye shields)
water levels can be raised by BENDING the tab on the bottom of the float which controls water level...much like a toilet tank float.
Also finally if soap levels are too high the soap will not rinse off regardless of the amount of "rinse fluid you use.
Visit www.soapman.com
regards
soapman Bruce
Dec 30, 2007 | Dishwashers
Zanussi ZWF1440 Front Load Washer Logo
107 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
