Question about Nelson SoloRain Hunter Valve Adapter
Solo Rain 8014. Where is the plunger located to clean. Valve won't open
Pot continually fills on or off. trips breaker.
inlet valve is stuck open. remove the front plate and locate the inlet valve in the front at the bottom. shut off the water supply and unplug the brewer. remove the nut and solenoid, and, using a crescent wrench, remove the valve shaft. take out the small metal plunger with the spring and stretch out the spring a bit. clean out any residue and put it all back together.
Apr 14, 2014 | Bunn CWTF15-TC
Water floor after hard rain
If you have a sunroof I would start with looking at the drain tubes take a solo size cup of water and open the sunroof now pour the water in the tracks it should start to pour out in the front behind the wheel and in the back in front of the wheel if not the drain tubes my be clogged causing it to overflow the best way to clean out the tubes would be to use a hose our blow compressed air into the hose but not to hard as you could pop the hose out of its place
Apr 03, 2014 | 2003 Nissan Maxima
Nelson solorain 8014 manual
Buy a new timer. Sounds like the circuit board has a short. or call the manufacturer number should be in the instructions.
May 18, 2013 | Signature Control System Signature 77516...
Hitachi NV45AB won't advance nails
This problem could be caused by the head gasket fliped the wrong way not sealing small hole in the body. Also the head valve gasket (small round gasket between headvalve and head) could be place with vent hole mis-aligned. Check these two items and post again.
Jan 22, 2013 | Air Tools & Compressors
EGR valve needs to be replaced how do I replace it or how can I clean it out?
Well if your going thru the trouble to remove it. It's a real toss up I know the part is expensive. If all it needs is to be cleaned then clean it, if it doesn't hold vacuum or open when it's needed then replace it. As far as the actual proceedure, the egr is always located in an nearly inaccessible location on the engine. So you get frustrated and take it to a mechanic and he gets frustrated but then he's getting paid. It has 2 or 3 bolts and a vacuum line, either metal line or vacuum hose. After removal if it's clogged it will look black inside gummy sticky clean it with carb cleaner, don't spray it soak it to remove the mess it's not very big inside, it has a plunger, a rod and a small chamber, after cleaning apply vacuum to it to make sure the plunger opens and closes ( it will move) There is no lube for this part exhaust gases pass thru it hence the name Exhaust Gas Recirculation, Hope it helps
Jun 02, 2010 | 1996 Nissan Maxima
Miele dishwasher doesn't work.error F70
When this problem happened to our machine, it was simply the pipes under the sink where the dishwasher drain pipe fits were blocked with muck. This was preventing the one way valve connecting the drain hose to the household waste from fully opening thus preventing the machine complete its drain cycle.
Solution was to thoroughly clean the sink drain pipes - plunger, power plunger and then a dose of chemical cleaner. Dishwasher is as right as rain now:)
Mar 29, 2010 | Dishwashers
Why would my 1995 honda accord be idling?
There are two valves that control air flow to the engine and can affect idle:
IAC Valve: (Idle Air Control) this is a $220.00 valve that bolts
onto the throttle body. It consists of an electrical motor and a
plunger that moves in response to a computer on the vehicle someplace.
There are great instructions in the "Hanes" manual on how to test this
part.
FITV: (Fast Idle Thermo Valve) this one costs $55.00. This little
puppy is not electrical defendant. It is a "thermo" switch. There is
a wax plunger that expands when warm and shrinks when cold. When the
engine is cold, the valve is completely open, increasing the air flow
to the engine to warm it up faster. As the engine warms, the plunger
expands and lets less air into the engine to slow down the idle.
One (AIC) is bolted to the back of the throttle body close to the wall of the dashboard. The other one (FITV) is bolted to the BOTTOM of the throttle body. Each one of these valves can be removed and tested and CLEANED WITH THROTTLE BODY SPRAY. Always clean before buying a new valve.
Sometimes the IAC valve may not have problems. You should take it off and
clean it. Then take off the Fast Idle Thermo Valve and took it
apart to clean it. I discovered that the entire inside is supposed to
be screwed into place on the assembly. Apparently the center/core of
the valve has slowly, over time, juggled out and the air was leaking
through regardless of what the little plunger was doing.
Thank You for contacting Fixya.com
Aug 03, 2009 | 1995 Honda Accord
1998 ford escort
replace the idle speed control air bypass valve.
Mar 02, 2009 | 1987 Ford Escort
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Nelson SoloRain Hunter Valve Adapter Logo
201 people viewed this question
Top Nelson Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Nelson Hardware and Accessory Expert? Answer questions, earn points and help others
