Slide projector I was using my kodak ektragraphic slide projector, when I first started it up the fan made a noise. I quick restarted it and it all worked great. I used for about an hour. Now when I turn it on "nothing" no fan , no light. Is there a reset button or something. Thanks Kevin kstotesbery@yahoo.com
    Problem Solver:
  • 18 Answers
No, there is no re-set...there is however a thermal-coupler which will burn out instead of your projector burning up. It is close to the "Kodak" name plate inside and right behind the lamp socket. You CAN by-pass this unit but I don't reccommend this since it then could become a fire hazzard. We still repair those: www.flcamerarepair.com
Posted on May 14, 2008
Kodak slide projector 4400 developed a noise when last used. Is it safe to continue using?
If the new noise is constant, check the cooling fan for debris of some sort stuck in it.
Do not use the projector if the fan is not working as it might overheat and ruin your slides.
Aug 28, 2016 | Kodak Carousel 4400 Slide Projector
Fan noise Slide Projectors
Fan noise on a Carousel 4200 Slide Projector is usually not the fan at all - - it is usually caused by the fan or mechanism drive belts (they stretch out and loose their elasticity over time & wear). Replacing the belts and re-greasing the fan axle should quiet the projector down nicely. The belts can be purchased from: www.micro-tools.com
Words of warning:
* This replacement will require an almost total disassembly of the projector.
* Do NOT interchange the belts!!! They are size-specific.
Jim
Feb 12, 2014 | Kodak Office Equipment & Supplies
Kodak av 1050 slide projector with noisy fan motor
You can try a very small amount of a synthetic machine oil ( NOT WD-40!!!), but chances are if these machines have a bunch of hours on them the fan bearings (or the fan) will need to be replaced. The good news: you can contact www.micro-tools.com for Ektapro (or most any Kodak Slide Projector part). They have an amazing inventory of parts for Kodak machines and great technical support! Good Luck !!
Jim
Jun 07, 2012 | Office Equipment & Supplies
Kodak Slide Projector not moving carousel
Chances are that the LINK that connects the cycle solenoid plunger to the cycle lever is broken. This happens a lot on this generation of projectors. You can purchase the parts from: www.micro-tools.com, as Kodak no longer stocks parts. micro-tools should be able to provide installation instructions! Good Luck!
Feb 21, 2012 | Kodak Office Equipment & Supplies
Kodak Ektagraphic model B-2 slide projector.- It does not start. I checked the power cable and motor OK but I don't know how to reach and check the thermal fuses. I also don't know how to reach the...
If the motor is "OK" (turning), then it's not a fuse, it's the belt that the motor drives to power the slide change mechanism. There are 2 belts: 1 that drives the fan & one that drives the slide change mechanism.
Nov 02, 2010 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
I have an old Kodak 760 carousel projector with 140 slide rotary. Can I get replacement rotary slide holders?
You can buy new & used Slide Trays for Kodak Slide Projectors from: www.vinevalleyimaging.com They have amazing connections with slide projector users!!
Oct 15, 2010 | Kodak BC-4401 Slide Projector
Problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
May 25, 2010 | Kodak Carousel 4600 Slide Projector
124 people viewed this question
jasbo
jasbo
