Question about Dorel Baby Gear
How to install car seat in ford escape - Dorel Baby Gear
Is there a back hook up
Posted on Feb 19, 2014
Lay down back seats on my 2015 Ford Escape
should be on the side of the seat, sort on the back bottom or up some on the back seat.. or even a strap to pull up to lower the seat..
Dec 28, 2014 | 2015 Ford Escape
2001 Escape: airbag light comes on,blinks, and then is a solid light. Is this probably a costly repair to fix?
This happens with my '01 Escape all the time. After extensive research on this I discovered Ford installed some really horrible wiring clips under the Driver's and Passenger's seats. Fixing the problem is just a matter of getting under your seat and disconnecting and reconnecting those little wiring clips. Mine are bright yellow and the only wiring under either seats. I heard a couple of guys got fed up with the problem and replaced the wiring on these, but I find it easier to just fiddle with them whenever the airbag light illuminates.
Ford did acknowledge this issue and didn't issue a recall because the airbags will supposedly still deploy in the event of a collision. I don't recall where I read this but I felt relieved by it :). If this issue really bothers you go get it diagnosed, the diagnosis wont be pricey, the fix might be though! Good luck.
Apr 10, 2013 | 2001 Ford Escape
I need more length on my 2011 Ford Escape with power seats..doesn't go back far enough?
Your only option is to modify the seat mounting
This is the second Escape question I have seen
for that issue
It would take someone with fabricating & TIG Welding
skills-- but could be done
Mar 09, 2013 | Ford Escape Cars & Trucks
My seat will not go forward or backward on my 2003 ford escape
might try checking the fuses first. may be connection problem under the seat if fuses are not the problem. could also be switch or even the motor on the seat. hopefully just a fuse. good luck and hope this helps some
Aug 11, 2012 | 2003 Ford Escape
How to remove front seat headrest on a 2008 Ford Escape? Have new seat covers and need to be able to remove them to install.
There is a Pin hole on one side of the headrest in the plastic base. You have someone put a small Allen wrench in the hole till it presses against the metal spring and also on the release on the other side, then pull the headrest out. You will have to press on the spring to put the head rest back in also.
Dec 27, 2010 | 2008 Ford Escape
How do i put the back seat down in a ford escape 2003. bought the car used with no owners manuel
Lift up on the rear seat cushion and fold it towards the front. Now pull the lever and fold the seat down.
Apr 27, 2010 | 2003 Ford Escape
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Back seat belt replacement
Due to this being a safety item all parts and install must be completed by the dealer.
Jan 15, 2009 | 2005 Ford Escape
Baby Gear Logo
371 people viewed this question
Top Dorel Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Jim Goldsmith
Jim Goldsmith
Are you a Dorel Baby Gear Expert? Answer questions, earn points and help others
