I have a Kodak 3250 printer with an error code of 3524. I've removed the back paper cover, with no results
4 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: Kodak esp 3250 printer error.
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
1. Open the printer access door.
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Jan 29, 2011
caroldon
  • 17130 Answers
SOURCE: My new kodak printer says
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now remove the covers and reset and check the printer properties to see the ink levels.
Activate head cleaning before a test is taken.
Posted on Sep 17, 2011
SOURCE: when i try to print with my esp 3250 it says
on the back there is a gray cover on the back right side there is a tab u push in and pull it out but mine is doing the samething and there is no paper in it
Posted on Sep 13, 2010
My printer is showing an error code 3524 (paper jam) yet there is no paper jammed. It says press OK to continue, but just instantly returns to the same message. It does seem that the cartridge head is
had the same problem it only happened when i turned the ac off . humidity i guess. i started buying paper made for a inkjet cost a little more but it seems like it helping.
Oct 24, 2014 | Kodak ESP C310 AllInOne InkJet Printer
Kodak ESP Office 2170 Paper Jam code 3524
Actually, to fix it, you need to disassemble the printer.
The smallest part inside the printer can trigger this error code. The printer needs to be taken apart, clean, check the paper feeder that it's not crooked or missing a piece.
I recommend that you take it to a profesional, because if you do it yourself, you need to have a bottle of crazy glue, in case something breaks, that's how we fix it.
May 16, 2017 | Kodak ESP Office 2170 All-in-One Printer
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Feb 02, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Kodak esp 3250 printer error. Remove rear access cover. Clear all paper. Attach cover. I removed the paper, and pressed "ok" to continue, reattached the cover, and it still says this. I tried...
Thanks, Joe
Jan 29, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
There is a paper jam in my printer and i have removed to rear cover but there was no paper that was jammed.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
When i try to print with my esp 3250 it says error: paper jam remove rear access cover. clear all paper. attach cover. press OK to continue.. but it doesnt work???
Jun 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
2,635 people viewed this question
jasbo
jasbo
