Question about MSI K8MM-V Motherboard
I need to find the bios reset on the motherboard
    Brigadier General:
  • 10,406 Answers
Look for THREE gold pins in a row, and a jumper connecting pin #1 to pin #2.
With the computer turned off, and the AC power *UNPLUGGED*, move the jumper from #1/#2 to #2/#3, wait 5 seconds, and move the jumper back to the #1/#2 position.
You have just "reset" the BIOS.
Posted on Aug 22, 2010
Tip
Resetting BIOS manually.
Most of you guys may know this already, Any how some people still as k this question. So if anything goes wrong with the settings of the BIOS and you are unable to change the settings back you will need to reset bios manually. to this the easiest way is to remove the Button cell on the PC`s motherboard and wait for 10-20 seconds and re insert it. Your BIOS will be reset, Also most motherboards have a button or a jumper to reset the bios but you will need to consult the documentation that came with the motherboard to locate it.
Hope this tip helps some pepole out.
on Apr 17, 2010 | Computers & Internet
How to reset BIOS on Gigabyte GA-H55M-UD2H. Here's my story. A long while ago, I set a password to my BIOS. But then almost 11 months later, trying to use it, I can't remember the password. Is...
check your motherboard manual fo CMOS reset jumper location on you motherboard, and follow the instructions on resetting to defaults. Keep in mind that any customisations implemented by you in bios will be lost, so you will need to do them again.
Hope that helps
Cheers from NZ
Jun 19, 2011 | Gigabyte Computers & Internet
Reset bios on motherboard
Try following the instructions on this WikiHow: http://www.wikihow.com/Reset-Your-BIOS
Mar 14, 2011 | Computers & Internet
I still have the error message chassis intruded system halted even if i already did reset the bios please help
You need to remove the CMOS battery and reset the bios. The CMOS battery is usually the coin battery on your motherboard- remove it for about 15s, then insert it back and proceed with resetting the bios.
Oct 03, 2010 | ASUS P5P800S Motherboard
How to reset the BIO Password..???
Hi, Reseting the BIOS password is quite easy, you just need to unscrew the bottom plate and look for the CMOS battery underneath. all you need to do is to remove the battery for a few minutes then plug it back in. you should be able to go to your BIOS setup screen.
Thank you using Fixya. Your recommendation is highly appreciated.
Sep 28, 2010 | Lenovo 3000 N100 Notebook
How to reset the bios p4 titan ga-8id533 motherboard
As the computer starts up hit the Del key, that will take you into the BIOS utility, once in the BIOS load optimized defaults, this will reset the BIOS configuration.
Failing this just remove the power cord from the back of the computer and take the motherboard battery out for 20 minutes, this will fully reset the BIOS so you will have to input the time and date.
Regards.
Jul 14, 2009 | Gigabyte GA-8ID533 Motherboard
Reset BIOS
In order to reset BIOS you need to remove the CMOS battery located on the motherboard and re insert again
Jun 20, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Computer Monitor Switched OFF By BIOS SETTINGS
You will need to reset your BIOS setting to its default.
Every motherboard is equip with a jumper called clrtc (Clear RTC), look in your motherboard manual to find out how to use it to reset your BIOS. Or if you know the type of your motherboard, please share it.
Dec 14, 2008 | Intel Motherboard
Bios
If you have lost your bios password, only way out of this is accessing the motherboard and resetting the cmos.
If you access the mothernboard you can reset the bios removing the little coin battery from motherboard for one minute.
There is also a 3 pins bridged contact, near to bios chip, if you move the contact on the other two pins it will do same as removing battery.
Aug 28, 2008 | Intel Motherboard
MSI K8MM-V Motherboard Logo
179 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
