Question about Goodman CKL24AR24 Air Conditioner
The water is under the coils - Goodman CKL24AR24 Air Conditioner
  • 139 Answers
If their is water in the out side unit dont worry its from the rain .if its inside coil.. their is a pan to catch water from the coil, thats normal. .maybe the drainline is clogged inside not enough info ..good luck
Posted on Aug 23, 2010
HAVE A GE REFRIGERATOR TYPE TFX25CR THAT LEAKES WATER FROM TIME TO TIME, ABOUT 5 OZ
The evaperator for the drip under the bottom of the unit is probably dirty or has gone bad. Pull the fridge out and look under the bottom and you should see a pan with a coil above it. Clean the coil and the pan. If this does not correct the problem, then a new coil is in order. Also vacuum the back of the fridg if it has exposed coils to increase efficiency.
Dec 15, 2014 | GE Refrigerators
Where is the defroster
Defrost on most units works like this. An electric wire heater is embedded in the cooling coil where the air is cooled. A timer periodically shuts off the refrigerator and turns on this electric heater coil which melts the frost off the coil. The water from this defrost collect s in a trough below the coil and drains down thru tubes into a shallow plastic tray under the unit. The water does not collect there but is evaporated over time by the hot air that blows over top of the water by the fan that comes back on when the refrigerator returns to cooling cycle. This is the fan that sucks air from the room over the condenser coil under the fridge to make the refrigeration work. The air is warm after passing over the condenser coil and then the air passes over the water tray. You can feel the warm air returning back into the room if you out your hand down near the floor.
Mar 16, 2014 | GE GSS20IEP Side by Side Refrigerator
Kenmore Refrigerator by Whirlpool, model 106, top freezer. Water drips into refrigerator from freezer. I have de-iced the coils in the freezer, under a flat panel. I made sure that water flowed from the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | Refrigerators
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck,
Gene
Aug 10, 2011 | Whirlpool Refrigerators
There was standing water in the bottom of my Roper refrigerator under the crisper drawers. The drain pan under the fridge was dry. I cleaned up the water and vaccumed under the bottom of the fridge. ...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer.
Good luck
I hope this helps
Gene
Jul 31, 2011 | Refrigerators
There is a leak of water in front of the Air Conditioning unit
Clean floor of unit under coils so front coil water can drain under the coils to the back drain.
Don't forget to tilt them unit a bit to the back to allow the water to drain towards the back.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 23, 2010 | Frigidaire FAC084N7A Air Conditioner
Water is streaming out the bottom of my fridge on freezer side
the water should evaporate when hitting the coils,maybe coils s/b cleaned (dusty)
Mar 17, 2010 | Refrigerators
The unit is dripping water from the opening in the ceiling of refridgerator
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Whirlpool Refrigerators
The inside of the refrigerator get full of water condensation(lots)
It is not condensation
Sep 14, 2009 | Amana Refrigerators
Goodman CKL24AR24 Air Conditioner Logo
27 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
