Question about Crosley CA18WYR Thru-Wall/Window Air Conditioner
Fan runs at all speeds but compressor does not kick in to cool at any position. Vent is closed and thermostat is installed between left side of coil between 2nd and 3rd coil. I have a tech diagram that mentions an overload switch to the compressor. Where is that located? Or, does it reset itself?
  • 139 Answers
The over load resets ,.their maybe a broke wire.. the start capacitor for compressor sounds bad.. look for wires that are burnt or off at thermostat, capacitor, compressor .if capacitor is bulging at the top or leaking acid its bad good luck
Posted on Aug 23, 2010
How to replace coolig fan sending unit on a 2008 chevy uplander
Why ? Did you test ? Hook up a scan tool to see if the PCM/ECM - engine computer is reading coolant temp. ? Testing not guessing ? Do you even know how the system works .
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the ECM supplies the ground path for the low speed fan relay, which is Fan 1 Relay, through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from Fan 1 Fuse 29 through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the Series/Parallel relay, which is the Fan 2 Relay, and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. The ECM supplies a ground path for the high speed fan relay, which is the Fan 3 Relay, and the Series/Parallel through the high speed cooling fan relay control circuit. This energizes the Series/Parallel relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the Fan 3 Relay coil is energized, the relay contacts close to provide battery positive voltage from Fan 2 Fuse 33 on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
Feb 27, 2017 | 2008 Chevrolet Uplander
My 07 Saturn Relay shows ac off for engine protection but the gauge shows cold. The hoses feel normal. What is happening?
A/C Off For Engine Protection
Refer to Cooling System Description and Operation
DTC P1258: Engine Coolant Overtemperature - Protection Mode Active.
This is something you need to take to a qualified repair shop .
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) or engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 maxifuse® through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation, the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 2 relay and the cooling fan relay through the high speed cooling fan relay control circuit. This energizes the cooling fan relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 maxifuse® on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Nov 20, 2016 | 2007 Saturn Relay
Fan is not working on 2001 Chevy Silverado 2500 truck radiator fan motor?
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Your best bet would be to take your vehicle to a qualified repair shop !
Relay Driven Dual Cooling Fan Diagnostics
Aug 19, 2016 | 2001 Chevrolet Silverado 2500
Where is the fuse for motor fan in uplander 2006?
there is 2 fuses that you have to check
one will be in the big fuse assembly in the engine bay, the other probably in the fuse assembly in the cab
If they prove ok then it is possible that the coolant temperature SENSOR is faulty and needs replacing
don't confuse it with the temperature sender which operates the temp gauge.
Aug 10, 2015 | 2006 Chevrolet Uplander
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Cooling Fan Control - Two Fan System
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
May 01, 2015 | AC Cars & Trucks
2004 Venture Chevrolet minivan cooling fan circut
Are you talking about the radiator fan? How hot does the engine get in degrees F? Some makes and models, the radiator fan won't turn on till about 220 degrees F. Check for applicable trouble codes, see if any code that refers to the radiator fan circuit or coolant temp sensor? Some of the national brand auto stores will check codes for free.
Of course, as far as overheating in general, you have the thermostat--water pump and other possible issues. Are you losing coolant?
Dec 14, 2014 | Chevrolet Cars & Trucks
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
No cooling
Look at the back wall on the left hand side. "near the middle shelf"
If you find a wet spot or ice ball odd are you will need a Evaporator coil.
See if the fan is running when you open the door. By pushing the fan and light switch closed. "light will go out, Fan should come on" easy way to see if thermostat is telling the compressor to run"
Sep 03, 2012 | Sub-Zero 561 / F
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer same temp.
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Sep 16, 2009 | Amana ASD2326HE Side by Side Refrigerator
Crosley CA18WYR Thru-Wall/Window Air Conditioner Logo
118 people viewed this question
Top Crosley Heating & Cooling Experts
David White
J Rosado
Kiri Amarakoon
Are you a Crosley Heating and Cooling Expert? Answer questions, earn points and help others
