Question about Nordic Track /proform Treadmill Drive/motor Belt 118016
My Nordic Track exp 1000x started stopping after 25 mins at 3 mph everyday now. It starts again after 5 mins. Any ideas what to try.
  • g_rosengartn Aug 23, 2010
    I reset the breaker on the treadmill after 5 min and starts again.
Your walk belt is worn. The friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside) When the belt wears out the cloth on the underside becomes flattened causing too much surface area to contact the walk board
Posted on Aug 23, 2010
I have a Nordic track EXP 1000 the only keys that work are the start button and 1 mph. Other than that nothing else works. Not sure if it is the controller or the council. Any suggestions?
I had the problem years ago and I contacted NorcTrack and their solution was to replace the entire console for about $400. They wouldn't replace the pads or anything else, all they would do is sell me the new console. That was not going to happen since I had only had the thing for about 5 years at the time. I wasn't going to be putting that kind of money into that treadmill every 5 years or so.
I tried many things and I finally decided to buy a new console pad from the Treadmill Doctor. I think it was around $100. It was easy to replace. I just removed the screws holding the console cover in place, unplugged the wires leading to the lower console pad and pulled it off. The new pad fit exactly into the space the old pad occupied, I plugged it in and it worked. It's still working about 6 years later. I use this treadmill daily without any problems. It's not anywhere near as nice as the new units I see out there today, but it does what it's supposed to do and that's all I need.
The Treadmill Doctor has all the parts you need for this machine at a reasonable price. Much cheaper than Nordic Track.
Mar 15, 2014 | Nordic Track Nordictrack Exp 1000...
Belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
Mar 26, 2013 | Nordic Track NordicTrack A2350 Pro...
I have a norditrack exp 1000x, on the lower part,of the control panel,the functions,have stopped working.but the upper function keys are ok.what do think is wrong.?
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Aug 11, 2010 | Nordic Track Nordictrack Exp 1000...
How do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Aug 01, 2010 | Nordic Track Nordictrack Exp 1000...
I have a Nordic Track EXP 1000X treadmill and the power incline doesn't work. What should I do? How can I fix it?
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
Jan 24, 2010 | Nordic Track NordicTrack Treadmill, A2550
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Have a nordic track exp 1000x treadmill and the belt is slipping
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Nov 01, 2009 | Ironman Fitness Achiever Elliptical...
Nordic Track /proform Treadmill Drive/motor Belt 118016 Logo
392 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
