Question about Janome Memory Craft 9000 Computerized Sewing Machine
I have a Janome 9700, and when ever I break my needle whether it is my fault or not 99% of the time I have to replace the bobbin case, if I don;t my bobbin jamms up badly, I clean the bobbin case every week and am so careful with it. I just find it very unusual that with this machine I go through so many bobbin casea and yet my other Janome, I have had it for 3 years and never ever had to replace it. I still have 1 month warranty with this machine should I mention this to the dealer as I have many times. thanks Evita evitaw1@yahoo.com.au
Absolutely! I love my machine and have not had any problems.
Posted on May 05, 2008
I cleaned my machine, inserted the bobbin case and now there is a wire on the right sticking up. Where does it belong and how do I put it in place?
Posted on Aug 17, 2011
I have a janome 5124 and the bottom stitching is breaking every so often. I have cleaned the bobbin case , put a new needle in but it still won't work?
Could be one of multiple problems. Be sure to use only fresh, good quality thread--no old or bargain bin threads. Check if there is a burr or rough spot somewhere in the bobbin thread path that is catching the thread and breaking it. (You can hand rotate the handwheel and watch the needle/thread action in the bobbin area and watch what is happening.) It could be that the bobbin thread tension is too tight, or the bobbin case may even need to be replaced (they do wear with use).
Jul 11, 2017 | Janome Sewing Machines
Full rotary hook does not fully rotate
The hook timing is probably off. Needs to go in to the shop.
Sep 17, 2014 | Janome Sewing Machines
Elastic thread pulled too tight in Janome Sewist 525S
I would say your tension spring is shot on your tension assembly. replace it.
Mar 27, 2017 | Janome Sewist 525S Mechanical Sewing...
Janome 9700 suddenly is showing warning. Raise
Ask the seller! He has a vested interest in helping your machine work! As a former newspaper writer, believe me, if you send something to a local rag, about your problems with your Janome, the seller will sit up, and take Notice!
Oct 23, 2013 | Janome Memorycraft 9700 Computerized...
Bobbin case problems
Oh wow. That's definitely not good. Well you'll need to replace the bobbin case, and needle plate. Even the slightest burr can cause havoc. you could try smoothing down burrs with some fine sand paper but you'll need to replace the case eventually if you can't get this problem identified and fixed.
Next look for a build up or stray threads under and around the needle plate/bobbin area. Make absolutely certain you have the right needles for your machine.
Sep 06, 2012 | Janome Sewing Machines
Bobbin case wont stay in place
the bobbin case may need to be replaced. it wouldn't hurt to have the machine serviced to make sure the hook & hook race are ok
Apr 19, 2012 | Janome Sewing Machines
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
How to fix new home machine it model No.731016401. model 360 manufactured by Janome its not sewing cloths. The thread is placed properly but when i try sewing it starts to break the thread. it turns in...
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
also check the thread take up lever to make sure the thread has not come off of it cause that can make the machine jam up also
Sep 20, 2011 | Sewing Machines
My Janome mc9700 is giving me trouble. I think it may be a tension problem, but I'm not sure: trying to get some advice before taking it to the dealer. I am in the middle of an embroidery project, and my...
1.check to see if needle is in backwards
2.the upper tension maybe to tight----check owner's manual for right tension
3.the needle may be bent--roll on flat surface to check
4.the thread maybe hanging up on the bobbin case
5.check this area for lint or fragments of old thread
6.check thread for knots, if notty replace
Jul 29, 2010 | Janome Memorycraft 9700 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
145 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
