Question about GE Dryers
Ge profile electric dryer-clean lint filter flashing light and dryer wont work
4 Suggested Answers
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Posted on Jan 24, 2009
FixinFax
  • 3085 Answers
SOURCE: GE Profile electric dryer continues to stop and
You should get one of of those long handled dryer vent brushes from Home Depot or Lowes and clean the vent pipe also. Not enough air is moving over the vent sensor.
Posted on Nov 27, 2009
Why is there no air blowing out?
Sound like the Lint Trap and Blower area is impacted or a Bad Blower Wheel
Sep 15, 2014 | GE Profile Harmony DPGT750EC Electric...
How do I clean lint from inside GE Harmony Profile Dryer?
You have to remove the panel. The assume the lint filter works better then they usually do and do not make it easy to open up and clean inside. You may have to open it from the back side which does open up to allow repairs, etc.
Aug 12, 2014 | GE Profile Harmony DPGT750ECPL 7.3 Cu. Ft....
Clean Lint Filter Light/Possible Heat Problem?
Take the front panel off the bottom and check the big hoses that connect to the drum. From what you are saying, the fan is working but not drawing air through the drum. That is why the light is on because it is not sensing air flow through the connections to the drum.
Dec 02, 2013 | GE Profile DPSB620ECWW Electric Dryer
DPGT650EHMG CLEAN LINT FILTER LIGHT WILL NOT GO OFF
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | GE Profile DPSB620ECWW Electric Dryer
GE Profile electric dryer continues to stop and say check lint filter, however lint filter is clean?
Nov 27, 2009 | GE Dryers
Ge Adora Dryer, Worked great. Put load in, dryer 'hummed' drum did not spin. 'Clean Lint Trap' light was lit. Cleaned lint trap, still not working. Thought belt problem so unloaded dryer, drum did...
Sounds like your motor may be shot. Or possibly one of the pully's bearings are seized and is causing so much resistance the motor is unable to overcome it.
Oct 09, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Jan 24, 2009 | GE Profile DPSB620ECWW Electric Dryer
Fan is not working
exhaust fan on dryer is not working. I have cleaned the area at the bottom of the lint filter and cleaned the passage of the blower thoroughly.
Jun 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
314 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
