Question about Craftsman 24 Hp 48" Deck Yard Tractor
Fuel tank is the double sidedd top with a middle drop down under the seat well it has split omn the bottom and also hydrostaic fluid what kingd and how much
  • 760 Answers
Www.searspartsdirect.com
you will need your model number
Posted on Aug 23, 2010
How do you change in tank fuel pump on 02 model
Depends what car or truck. Some cars you can get to the fuel pump under the back seat or cargo space or drop the tank. On some trucks it's easier to pull the bed off then dropping the tank but may need to do both. When they build these autos they don't consider how the shop guy to fix them.
Feb 11, 2018 | Cars & Trucks
I HAVE A 2004 SONATA WITH A BAD GAS LEAK NEAR TOP OF TANK AND IT JUST LEAKS WHEN CAR IS RUNNING SO THURSDAY AFTERNOON I GOT UNDER CAR WHERE I HAD A GOOD ANGLE OF THE HOSES GOING INTO FUEL TANK AND WAT
google youtube and find out if there is a video pertaining to changing your fuel pump..U might be able to access it from under the back seat or from in the trunk...there for u wont have to drop the tank..sounds like a bad fuel hose from tank to fuel filter via Engine
Oct 24, 2014 | Hyundai Motor 2004 Sonata
Im going to need to drop my fuel tank in my 1986 camry. I have never done it before but I am capable. So If anyone knows how to do this please help. I dont want to break anything. First Im going to open...
First disconnect the negative terminal of the battery. Next left out the back seat. It is spring clipped in with two clips on the bottom left and right front of the seat. Pull clips forward and lift seat front up. I hooks in at the back so rotate the front up to unhook and lift out. In the middle under the seat is the gas gage float. Disconnect the wire connector and remove floor cover with Philips screwdriver. Then remove float from tank. This step must be done so you do not break the wire to the gas gage float. It is also the best place to siphon off the gas in the tank. Then you can remove the tank. You may have an exhaust shield to remove. The tank is held in with two straps hinged in the front and bolted in the back. Loosen the brake line clamps attached to the straps so that the clamp will slip when the tank straps are hinged down. There are several hoses and a gas connect to open. Open hose clamps. Disconnect fuel pump connector at back of tank. The fill hose needs to be worked off as you pull the tank down. There is one hose on the top back edge of the tank that needs disconnect after the tank is tipped down some. There is a rubber/plastic tank holder connected to the back flange of the gas tank. Remove the two corner screws but leave the guard connected to the straps. Remove the two strap bolts and hinge down to pull it out and disconnect all hoses. Mark with tape or some mean which hose when were.
Jan 25, 2013 | 1986 Toyota Camry
Fuel pump location for a saturn 1997 sl
it's most likely in the top of the fuel tank itself. you can drop the fuel tank to get to it but some cars have an access panel just for this reason under the rear seat. simply pull the bottom of the back seat out and you will see right away if it has one or not.
Jul 11, 2012 | 1997 Saturn SL
Where is the fuel pump located in the motor of a 1991 Honda Accord LX?
The fuel pump is probably located at the fuel tank. You will find the fuel pump mounted on the top of the fuel tank. There will be an access cover, about the size of a saucer, glued down with caulk under the trunk carpet just behind the back seat, or under the back seat bottom. Once you have located this cover, pry it up--I don't think there will be any screws. You should then be able to unscrew the plate from the top of the tank which will lift the fuel pump and sender unit. PLEASE OBSERVE EVERY PRUDENT PRECAUTION FOR WORKING AROUND FLAMMABLE VAPORS AND LIQUIDS! EVEN IF THE TANK IS EMPTY!
THE FUEL PUMP IS INSIDE THE GAS TANK. GOT TO DROP THE GAS TANK TO CHANGE IT.
Aug 16, 2010 | 1991 Honda Accord
How do you change fuel sending unit?
try to lift the the back passenger seat to see if you can access the fuel pump access, most maxima have access under the seat, you may not need to drop the tank.
Apr 28, 2010 | 2002 Nissan Maxima
How do i change my air filer under the tank, 01 tour deluxe
The air filter, should actually be under the rider's seat. Key latch to remove the seat should be on the left side just below the seat and when you turn the key it will pop it up. Lift the seat out of the way and you should see the air filter right next to the battery. Hope this works out for you okay!
Jan 03, 2010 | 2008 Yamaha Royal Star Tour Deluxe
Where is the fuel pump in a 1996 dodge avenger
it is in the fuel tank and this is a easy one. because most are not accessibly unless you drop the fuel tank! but on your vehicle it can be access by the access panel under the rear back seat bottom. remove the bottom of the back seat and you will see it right in the middle! unplug the harness , remove the panel and remove fuel pump and assembly up and out. good luck and if you have any more question please ask.real easy fix. good luck
Sep 23, 2009 | 1996 Dodge Avenger
Were is the fuel pump located?
The fuel pump IS located in the fuel tank. It is easily accessed in this particuar model, under the rear seat. If you have an arm reat in the middle of the rear seat, you'll need to go in through the trunk. Remove the cover from the the far back, between the back of the rear seat and the trunk space. Remove approximately 4 to 6 screws in the center piece of cardboard that attaches the armrest and rearseat to the cross menber of seperating trunk from seat.
From the back seat, grab the top of the back rest of rear seat, PULL HARD forward on left and right sides . This should disconnect the top. Then, on left + right-sides, toward the lower cushon, there will be a bolt, remove them.
Then pull up the bottom cushion.
In the middle of the floor you have left, where the bottom cushion once was, you will find the top of the fuel pump access. From the top there is a cable that goes toward the driverside, follow it to the connector which should be cover by a small piece of foam. Remember to diconnect the pump before attempting to service or replace it.
May 09, 2009 | 1992 Nissan Maxima
Craftsman 24 Hp 48" Deck Yard Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
