Question about Stanley Air Tools Compressor 16pc Accessory Kit Bostitch
I have a bostich/Textron CWT 30A oiless air comp 3/4 hpseems to be sucking air and blowing at same time..very low pressure output also.tank is not filling up & shutting off
    Champion:
  • 205 Answers
Most likely need new piston and sleeve kit or could be just needs new valves.these oilless compressors are ok for very lite use but if you run them hard they wont last
Posted on Aug 22, 2010
  • Garcia9127 Jan 30, 2012
    I had the same problem. I opened the piston frame and foun out that the spring wire valve was broken. It is alout two inches long by 3/4 in wide and about 0.015 thick.
    I am having a hard time locating the part
  • bobwhite_ok
    bobwhite_ok Nov 26, 2012
    Did you find that part? Think it might be my problem. bobwhite_ok at yahoo dot com
Hitachi framing nail gun, fires ok on a large tank shop compressor but on a portable compressor it continually blows air from the piston. The gun has a new o ring kit from a repair shop. They can't find...
the compressor is not putting enough air into the guns cylinder and the escaping air is a safety feature for safety. You need to get a larger comp or increase the pressure coming out of hose. there should be a gauge on comp. Set it for suggested pressure for each separate tool. Be Safe!
My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Jul 22, 2014 | Hitachi NR83AA3 Pneumatic Frame Nail Gun 3...
I just bought this unit took it home read the instructions loaded the gun with nails hooked up the cables opened the gauge turned on the unit and i waited for the tank to fill with air and the gauge...
There are usually two gages, one for the pressure in the tank, the other is for the regulated pressure in the hose going to whatever tool you have connected. I assume the tank filled up and the tank gage registers pressure in the tank. When you said you "opened the gage" I am guessing that you turned the knob counter-clockwise which would be the normal direction to open a valve. However, this is not a valve, it is a spring loaded regulator device. When you turn the knob counterclockwise you are removing all pressure from the spring which sets the regulator to allow zero pressure in the hose. Turn the knob clockwise to increase the pressure in the hose. I hope this was helpful. Good luck.
Feb 18, 2011 | Porter Cable Air Tools & Compressors
My air condition is not blowing cold air
best diagnostic method is dual head gauges. balanced pressure between low and high side in the off position is aroung 90 lbs. running low pressure is 20-40 lbs and high pressure 160-200, is the compressior not coming on? does it stay on, or click on and off. either might mean the freon level is low. try unplugging the low pressure switch on the low side supply line and shorting the pigtail wires together with a paper clip. does the compressor stay on now? if so and the air is warm or cool, freon is low. if the air is cold that switch is bad. if compressor still won't come on the list of possibilities grows longer: compressor, comp fan clutch, AC relay, restriction at several places... repair shop time...
Sep 04, 2010 | 1991 Buick Riviera
Starts up then shuts off and the primer button sucks in so its not getting gas. its not the vgas cap tried that already
You may try removing the fuel line from the carb, removing the gas cap and blowing air (low pressure or by mouth) through it to the gas tank. The in tank filter may be clogged.OR You can check by just seeing if fuel flows easily from the tank through the line.
Mar 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Portable oiless compressor wont pressurize
If there is pressure at the pump, either:
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
I have a westing house 3yc1 air compressor. The problem i'm haveing is that the motor thats on the comp is singal phase, and its spining the comp in the opposite direction of the arrow on the comp. The...
With piston compressors it shouldnt matter which way it runs. it sounds as if the non-retun valves may be damaged or not closing properly. this can be caused by a foreign object stuck in the valve. the valves are located in the head of the cylinder. Check The valves..
Oct 10, 2009 | Air Tools & Compressors
When tank is low on pressure, the motor cuts in but compressor struggles to turn and trips.
some compressors require an air release that drains the pump head when the compressor reaches full pressure if this is not working the compressor tries to start with full pressure on the pistons which is hard on the motor. If you always heard a small release of air when the compressor shut off yours probably had this feature. drain all the air out and if it starts fine that may be where the problem is. If its one of the smaller oiless ones the motor start capacitor is probably bad
Jul 10, 2009 | Psi Air Tools & Compressors
Compressor whining and blowing air. Sounded like engine siezing. 20gal oiless compressor
hi remove compressor unit try motor if ok strip comp hope this helps merlin v12
Jun 15, 2009 | Campbell Hausfeld 26 - Gallon Air...
Ingersoll rand air compressor 185
How old is the compressor ? This trouble shooting is directed to the vane and screw types of air compressors.
Caution,
For exact information on the equipment you are working on, go to the manufacturer’s maintenance and repair manual.
Here are some possibilities.
Compressor does not reach design pressure or capacity:
Air Pressure safety valve is leaking
Receiver air valve is open
Unloader valve is leaking
Loose Piping or fittings
Compressor will not load or unload:
Unloader valve defective
Air control valve is sticking or dirty
Unloader pressure is improperly set too high or too low
Water in the control lines
Plugged control lines
The air compressor CFPM is low:
Dirty air compressor air filter
Defective air intake control valve
High idle on power source improperly set
Damaged or worn rotor blades
Nov 23, 2008 | Air Tools & Compressors
Stanley Air Tools  Compressor 16pc Accessory Kit Bostitch Logo
638 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
