Question about Ovens
Hello, I have a Frigiaire oven. The LED always displays "F-11" and beeper is always beeping. I thank that the control box was broken. The information for control box is as followings: Spitfire Controls, Inc. SF5311-L8299 Rev D Modle No:316418229 Control #00-0004(Electric) 120VAC 60Hz 0622 4396 MEXICO Could you please tell me that where can I buy it? How much does it cost? How long does it take? Right now my family couldn't cook. please hlep me. Thany you very very much. Frank
  • 213 Answers
SOURCE: Electrical Jenn Air Oven control panel ..
theres no fuse. the display needs to be replaced. this is a common problem on maytag and jenn-air ovens
Posted on Nov 27, 2007
SOURCE: Kenmore Elect Built-IN Oven Model 790
OLD MODEL KENMORE STOVE.....THEOVEN DOOR IS LOCKED AND WILL NOT OPEN....NO F7 OR BEEPING SOLUTION....IT IS TO OLD...WE TRIED UNPLUGGING AND REPLUGGING. NADA!!!
Posted on Jun 23, 2008
SOURCE: "F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Posted on Dec 18, 2008
  • 30 Answers
SOURCE: kenmore electric built-in oven control panel beeping
There is a probelm with the control panel ribbon. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Posted on Nov 08, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
When buttons are pushed, no beeping. even when timer is set to go off, no signal that the time has expired
If all other functions are working and you just lost the beep sound then you have to make this choice. The beeper is actually mounted on the main control board. If it has gone bad--the only way to fix it is to replace the complete main control board which is an expensive part. One thing to check in your owners manual is if your control has a way to change the sound level of the beeper. If yes--it may have accidentally got shut off if it has that type settings.
Jun 16, 2015 | GE JTP75 Electric Double Oven
What does F7 meanon my ge oven
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | GE Ovens
Oven beeps and shows F7.
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Sep 29, 2010 | GE JGRP17 Gas Single Oven
Displays F-5 and beeping
Hello- Sorry - no good news here. The code described- F5 - indicates control board failure. The only solution is to replace the clock timer. Part is about 150$.  Installation is fairly easy, if cost is justified. These computers are the weakest link in modern ovens. If you do go with repair, avoid using the 'self-clean' function. This is the usual cause of control failure. Please acknowledge this post if informative.- Thanks-  Ed
Mar 19, 2010 | Frigidaire FEB27S5A Electric Single Oven
Jenn-Air Electric Oven - F-1 Code
You can disconnect the beeper so its not so annoying. turn oven off at breaker first. pull out oven a little so you can get at the top 2 screws on each side. The speaker is between the boards on the display module.
look for a red wire connected to a gold disc like speaker. remove this wire and you won't hear the beeping anymore.
Nov 27, 2007 | Jenn-Air JGW8130A Electric Single Oven
Hot point beeper wont stop
This is a code for an over temp condition.
If the oven is cool then there is a problem in the sensor circuit, usually a failed temp sensor.
Post back if you have any questions.
Nov 18, 2007 | Hotpoint SY21 Style Line Gas Single Oven
Ovens Logo
322 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
