Question about Garden
I have a shindaiwa 575 chainsaw that pumps to much oil on bar how do i fix it
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
Posted on Mar 06, 2009
SOURCE: Poulan-Pro 295 leaks excessive bar-chain oil
Most saws have a tendacy to leak after they are used. After use, just "burb" the oil fill cap to relieve any pressure. The closed oil system will siphon out all of the oil.
Posted on Aug 06, 2009
dontbother10
  • 2220 Answers
SOURCE: talon petrol chainsaw ac3100, bar lurication
The parent company is here:
http://www.talontools.com.au/html/about_talon.html
I couldn't find a parts list or any source for parts. You can download the operator's manual. This appears to be a Chinese chainsaw. Parts may be difficult or impossible to find.
A blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. The oil pump is often behind the clutch. The saw can be operated without the bar and chain to verify oiler operation. Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Once removed a GOOD local chainsaw sales/repair shop may recommend interchangeable parts.
Posted on Sep 21, 2009
Testimonial: "You have been a great help Thankyou"
  • 597 Answers
SOURCE: old homelite XL chainsaw pumping bar oil into engine while runnin
Check that the oiler hole and the hole in the bar that it pumps into aren't clogged. The sawdust running under the chain and be deposited in the oiler hole in the bar until it plugs it solid. That will keep the oil from havintg a place to go and build up pressure.
Posted on Sep 23, 2009
  • 699 Answers
SOURCE: bar not recieving oil
The problem is related to the internal oil pump. The followings are the possibilities:
  • Clogged line from the oil reservoir to the pump.
  • Clogged line between the oil pump and the chainsaw bar orifice.
  • Faulty oil pump itself (common in well used/old device).
Hope it helps.
Posted on Jul 28, 2010
Do I mix the fuel for my shindiawa 575 chainsaw
Re-fill with fresh fuel of the correct mixture
(Shindaiwa Premium 2-cycle Engine Oil
and gasoline-40 : 1 ratio;
other brands-25 : 1 ratio).
Workshop manual
http://www.golftechs.us/Manuals/shin%20chainsaw_current.pdf
Dec 12, 2016 | Garden
How to fix bar oiler
try cleaning the bar and all the oil gallaries in the bar and chainsaw body. Rinse the oil tank with varsol to clean dirt fron the oil intake strainer, reassemble and test. to test the oil pump leave the side cove, bar and chain off, start the saw and see if oil sqirts out when you rev the motor
Sep 29, 2015 | Echo PPT-265ES Pole Pruner
Chainsaw no oil Problems
If you are talking about the saw not oiling the bar, it's due either to a bad oil pump--a small gear pump or blocked oil passageways. Cleaning the passageways is easier than fixing the pump, so I'd start there.
Feb 23, 2012 | Homelite Garden
No oil to bar
Remove the nuts that hold the clutch cover on, Then remove the bar and chain. Make sure the port hole in the bar is open for the oil to flow into the chain groove. The oil ports can get plugged by sawdust and chips. Bar oil is sticky. The bar and chain should be removed and cleaned on a regular basis. Clean the groove in the bar too. Also make sure the port on the saw body is open. Start the saw with the bar and chain removed, if oil doesn't flow from the port, then you have a faulty oil pump and will need to go in deeper to replace the pump parts.
Always use proper clean chainsaw bar oil. Using other types of oil can burn up your oil pump.
Dec 27, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Just bought a McCulloch 32cc, Mdoel 3214 from a pawn shop with no manual. Does it require mixing oil with the gas and if so what ratio?
Fuel requires 2-cycle oil be added, bar oil is straight from the container.
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 06, 2010 | McCulloch Garden
Bar not recieving oil
Hope it helps.
Jul 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
What is the mixture of oil and gas
Husqvarna recommends 50:1
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 24, 2010 | Husqvarna Chain Saw 20" Bar
When I run the saw the bar dosent get oil evern though it has a atomatic bar oiler, yes it has oil in it
the hole on the oil pump hose may be clogged. take the bar off and clean it out good. if this doesnt fix it the oil pump may be bad.
Mar 21, 2009 | Garden
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
