Question about GE Wireless Optical Mini Mouse 3087897985
GE Wireless Optical Mouse 98763
Mouse was working fine, is linked and will point, but neither Left or Right click buttons will work--they press down but the pointer does nothing (cannot select information--will highlight buttons, but not select them). Any solution?
  • 2 more comments
  • Anonymous Jun 29, 2008
    not working with receiver!
  • Anonymous Oct 01, 2008
  • dnseaman Feb 16, 2009
    It worked gth very first time-someone has thrown away the packaging which is the only directions I had; I turnd off th4r dvic to sav on battery power and the 2nd time I couldn't get the mouse to function.
  • Anonymous Mar 03, 2009
    I cannot change the battery (no instructions) please help me to
    change the battery.
5 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: Batteries for GE wireless optical mouse
Normal 0 The GE mouse doesn't have a little door to open on the bottom, Try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Posted on Jan 20, 2009
SOURCE: GE Wireless Optical Mouse 98763 will not work. It
Check out the batteries on the mouse and the "reciver".
Posted on Jul 14, 2009
darkpain
  • 316 Answers
SOURCE: i had a wireless optical mouse 98763 but i don't
Hello there is on the market usb to ps2 adapter so you can connect it
Posted on Jan 20, 2010
  • 4 Answers
SOURCE: optical wireless mini mouse 98763 feature #9 is
I had all the same problems listed in fixit and found that all it took was placing all NEW batteries in the mouse.
Press the blue light button on the USB and the little black reset button on the bottom of the mouse at the same time. Worked good from there on.
Posted on Feb 28, 2010
Do I need a receiver plug-in for my Gateway laptop to use a GE wireless optical mouse model 98763?
Garrett, Yes, plug in the receiver that came with mouse. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Wireless Mouse and Driver Problem Fix
http://techin.oureverydaylife.com/ge-wireless-optical-mini-mouse-stepbystep-setup-13706.html
GE 98796 Wireless Optical Mouse Manual
Aug 22, 2016 | Gateway Computers & Internet
Can someone tell me how to underline from left to right the entire width of the page.
select all the text on the line . place mouse pointer at start of left side of text hold down left mouse button and drag mouse pointer to the right end of line.
click on the u with the underline icon when in the home tab
or press ctrl and u
Apr 02, 2016 | Microsoft Word 2010
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
I need to free up disk space
As a starter , you have to press the start button on your lower left, then choose all programs.. After selecting ( all programs ), select ( accessories) , then select system tools and last but not the least my friend, select disc cleanup. I hope this would solve your hard disk problem. If not, another option is that you have to delete any existing movies or game files that you don't use anymore. Frome your desktop, press the right button on your mouse pointing to what ever game or movie files that you need to delete. Select ( properties ), then select ( find target ) . When you found the main files of ether games nor movies, point your mouse pointer from the upper right part of all files then while holding or pressing down the right mouse button dragging somewhat a line to the bottom right of all files and dragging the mouse pointer to the lower left part of all files highlighting every files. When you released the right mouse button a choice will appear, select ( delete ). Have a nice day ! ! !
Aug 17, 2011 | Computers & Internet
I recently bough a GE 98812 mini wireless mouse and it worked fine until a week ago. Now the red light on the USB does not light up and the mouse appears not to be "linked" to the USB. How do I...
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
May 09, 2011 | Computers & Internet
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
The start button is in the upper left part how i can change it?
Upper left part of what? Most starts are on bottom left ..
Right click on the start and goto Properties and taskbar customize
Apr 08, 2010 | Microsoft Windows XP Home Edition
Optical wireless mini mouse 98763 feature #9 is
Feb 23, 2010 | GE Wireless Optical Mouse
Mini mouse GE 98763 stop working and I can't start
If you are using window you can download the software at:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Choose system and select wireless optical mouse
Jul 30, 2009 | GE Optical Mini Wireless Mouse 98793
Computers & Internet Logo
478 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
