Question about Norelco Cool Skin 7775X Electric Shaver
How long are the blades good for - Norelco Cool Skin 7775X Electric Shaver
    Guru:
  • 174 Answers
Norelco Cool Skin 7775X electric shaver replacement heads is Norelco HQ177 cool skin shaving heads.
Posted on Nov 20, 2012
  • Norelco Master
  • 1,602 Answers
Norelco suggests changing the heads every 12 months. You will find replacements for model 7775X at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq177-cool-skin-replacement-heads-p-245.html
Posted on Aug 23, 2010
When engaging the blades on my husqvarna 4823 the blades stop after a few second . If I shut the blades off and the reeng age the blades, they work ag sin for a few seconds
check to see if you have correct voltage to battery. needs to be at least 13 volts when tractor running. If that is good check connections at clutch. These have been known to loosen up or burn out.if that is good you either have a bad switch or bad clutch. Good luck
Oct 18, 2014 | Garden
Ryobi 9" Band saw blade
The problem might be blade drift, feed & speed rates. Are you using a fence? Do you have a good blade? I had pretty good luck with my Haltbar blades of www.sawblade.com . Does your blade track properly? Check this blog site . This might help too.
Jan 23, 2013 | Ryobi Saws
Replaced blades on LT 1018 series and the blades are making a grinding noise. Followed operators manual instructions, purchased proper replacement parts. can you help?
You did what you were supposed to do, new blades, proper installation, and you were happy with what you thought was going to be a good outcome. The problem is that the new blades are hitting the deck area. Old blades ware down , your mower deck was bumping into stuff . Now you have to go under with a hammer and hammer back the dents where the blades are hitting. You did very well to start, but now to finish you have to do a little bit more. You will be mowing again in no time. Good luck.
Jun 12, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Blade will not stay on wheels
Assuming the wheel tires are in good condition and the blade is in good condition, the only thing left is method of installation. Make sure the tensioner is disengaged and put the blade on starting with the blade guard (long thin channel at top), then around the wheels, then finally in the block guides ( the two small guides at the bottom. Make sure the set screws on the guide are loose as well). Next tighten the block guide set screws and then make sure the blade hasn't shifted. It should be sitting centered on the wheel rubber all the way around. If everything looks good, engage the tensioner and test run. On a side note, the wheel tires have small notches that work like gears that often pop up, make sure they are all pushed in properly. Good Luck!
Feb 07, 2011 | Saws
My original blade broke so i bought a new blade from wickes 10tpi now when i use it i saw on the line i have marked but on the other side of the 2x2 it is about quarter to hallf inch out how can i make...
There are good blades and there are cheap blades. Good blades are straighter but less tolerant of poor technique and so tend to break, cheap blades can and do bend far more. You can keep the blade straighter by not forcing the blade through the work and allowing it to cut at it's own rate and by experimenting with the speed settings on the jigsaw. It also helps if you pick the correct blade for the job: 10tpi is a bit too coarse for ripping a timber batten along the grain but fine for rough cutting chipboard. Also, it's difficult to keep the foot of the jigsaw absolutely level on 2x2 which adds to your problems.
Aug 15, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Good Evening, I cant get the circular blade to release from the stem. Any suggestions.
Good evening to you!!! Two q's? which way are you turning it and are you using your super special blade holder?
Remember, Off will be in the direction of blade rotation. It may be snug because it tightens when the the blade turns. Please make sure it's unplugged. Not funny and don't say it doesn't happen. Good Luck, Ned
Oct 06, 2009 | Wolfgang Puck Food Processor
Someone gave me an Oster A5 single clipper to sheer out goats, we are new to this. what size blade do we need and is there one or two blades on this clipper
Can't help you with the blade you will need to shear goats, but I can tell you that there are many blades for the A5, as well as many combs that fit over the blade to let you adjust for the length of coat you want to leave. Amazon lists many blades and combs under Oster A5 Clipper Blades. They probably have brief descriptions of what each blade is best used for, as well as customer comments regarding their effectiveness. There are a number of other places that sell blades if you look for them with Google. Also eBay, but there you probably won't get a description of what blade is good for what.
Good luck.
Sep 30, 2009 | Oster Golden A5 1-Speed Universal Motor...
Table saw blade wabbles alot when cutting?
This could be caused by several problems. First unplug the saw. Put a known straight edge against the blade (making sure not to contact the teeth) turn the blade slowly and watch for runout. Second make sure the spacers and blade flanges are on correctly. I would just about think it would be the blade. If you provide the model and brand I can do some more research. Good Luck
Jan 03, 2009 | Black & Decker DEWALT 12 In. 80 Tooth Thin...
Norelco Cool Skin 7775X Electric Shaver Logo
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
