Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
To get coins out from under the agitater. I removed the bolt, but had no luck in removing the agitater. Any suggestions?
  • 37 Answers
JimNeal406 --
The impeller has a friction fit after the bolt and washer has been removed. The dis-assembly diagram is available online at:
[http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114870.pdf]
You might get the impeller to release if you thread the bolt back in without completely tightening it and then use a wooden (or hard rubber) mallet to strike the bolt to push down on the hub basket drive assembly. Use a deep socket if you need to get better purchase. DO NOT use a metal hammer. A pulley puller may be needed to be used to remove the impeller. Write back if you need further help. -- SWT
Posted on Aug 22, 2010
Testimonial: "Thank you very much!! I will give it a try."
Vbsr2080woww
follow this steps and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dogs follow video.
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente of motor coupler
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Jul 09, 2013 | Washing Machines
Agitator not working wont wash water does drain
see this steps and fix it. GOd bless you
Agitator Dogs
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of motor coupler
Transmission
How to clean the screen under the agitater
Pull the fabric softener dispenser off the agitator, reach down and pull off the white cover (has 2 ears on it), then remove the bolt holding the agitator to the shaft. It then lifts off.
Jan 28, 2010 | Whirlpool LSR7333 Top Load Washer
I just fixed my whirlpool agitator mine has a removable cap in the top of the agitator. I removed that and there was a bolt down inside. I took that bolt out and removed a piece that had 4 cams on it,these cams work by catching the teeth inside the agitater. They get rounded off. you can replace them. they cost me 9 dollars
Oct 15, 2009 | Washing Machines
I need to remove the agitater from a 90 series kenmore washing ma
remove the top of the agitator by pulling hard at a 45 degree angle toward yourself, grab the plastic piece you see inside with a pliers and pull it straight out, use a 1/2 inch socket with extension remove the 1/2 inch bolt and lift entire assy straight out.
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 90 series washer 110.28902790
if you remove the agitater cap and the inside cap,you will see what they call dogs(4 of them)they wear out and the agitater will not wotk,if you remove the 7/16 bolt and pull the agitater off you can replace them and all will be fine,you can get them at your local appliance part store,please leave me a fixya-mike
Mar 12, 2009 | Kenmore 15864/15862 Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Estate top load washer
it you pop the top on the agitater you will see 4 gears called dogs, remove the 7/16 bolt upll the top half of agitater out and replace the dogs,you can get them at your local appliance part store,let me know how you do-mike
Oct 27, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Grandma's nylons wrapped around the bottom of the agitater
now you need to pull upward firmly but hard.  there are small splines holding the agitator in position. carefull if the agitator has two parts to it as there are usually plastic (dogs)inside which could spring loose if you are not careful.
Oct 24, 2007 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
606 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
