Question about Boating
How do I replace a rusted out threaded grease fitting on my omc 165 i/o? I bought new fittings but now the hole is too big.
  • 2,926 Answers
You will need to purchase a Heli Coil kit. This kit will allow you to drill the hole to a larger size, then a special tap in the kit will rethread the hole to a special thread size, then the helical (threaded insert) will be installed into the larger hole, restoring the threaded size back to what it once was. Great tool, used it many many times.
Posted on Aug 22, 2010
How can I remove the pressed in grease fitting on a 1930 Ford
Grab it with a good set of vice grips and work it out, I have had grease fittings that won't take grease and some of them the parts had to be removed and the lube hole cleaned out. you can also buy a grease injector that is a hollow barrel with a plunger that fits down in it and you pull out the plunger fill the barrel with grease install the plunger, place the injector on the grease fitting and hit the plunger with a good size hammer
Jan 12, 2016 | Ford Cars & Trucks
2000 ford f250 front hub dry
The hub should have grease in the taper bearings that go on the stub axle. If the grease was missing and the bearings were dry and rusted then the grease seal in the hub had failed and water was let into the bearings. Replace with new bearings and repack with a water resistant grease. Fit new seal .
Apr 01, 2013 | Cars & Trucks
How do i grease the ball joints 1992 Nissan Sentra E
Here's a link to the lower ball joint,it tells you about a fitting to be greased,as you see the ball joint has a hole at threads where greasing fitting will be.It will be best to jack up and remove tire to grease,look for other grease fittings,wipe up excess grease.Also check ball joint for wear,may need replacing.
Jan 20, 2013 | Nissan Sentra Cars & Trucks
How do i get the piston out of the front brake master clyinder
Two ways... once the caliper is removed.
1st, but this is a little dangerous, put a piece of wood where the pads would go and use compressed air where the brake line banjo fitting goes. The piston will come out like a cannon ball.
2nd, messy but safer, i got a bolt that threads into the brake line banjo fitting hole. drilled a small hole through the length of it in the center, and then drill and tap to allow a grease fitting to go into the top of the bolt, thread this into the caliper, and pump grease into the caliper which will force the piston out slowely.
Dec 11, 2009 | 1980 Yamaha XJ 650
Cub Cadet lt-1050 can't steer
If you purchased this unit from a home center etc. they never set them up or grease them ... if you can not steer this unit it was probly never greased at set up . you may need to remove the front spindles from the axle and remove the rust. before you reassemble be sure the grease fitting is not pluggedd up with rust as well , reinstall replace retainingclip( you will need to get a new ones) and grease your machine, also the mower spindles have grease fittings as well that need to be greased but the spindles need to be taken apart and the inner bearings seal removed to allow grease to enter the bearings
Aug 20, 2009 | Garden
Upper and lower ball joints
Jack the truck clear of the ground and let the wheel assembly hang. After you remove the tire place your jack under the lower control arm so it's firm. Remove the cotter pin, if you have one and loosen the big nut almost off. Wedge a "pickle fork" between the control arm and the spindle and give it a belt with a hammer until the ball joint pops. Raise the jack so you can undo the nut easily and separate the control arm and spindle.
The upper ball joint is riveted or bolted in. Grind the rivets or use a cold chisel and remove the ball joint. Clean up the area with some sandpaper, dirt , loose rust, etc.and put the new joint in. Put the spindle back on using the jack if necessary and put the nut back on and tighten.
The lower ball joint is pressed in. Tie the spindle out of the way and brace the lower control arm with some blocks or the jack if you have to. A few whacks with a hammer should pop the joint out. Clean the hole out lightly, just to remove loose rust and dirt. Put the ball joint, minus the grease fitting ,,in the hole and use the jack with a block of wood, to put it in place.You may have to fiddle with the spindle to make sure it is lined up. I've never had any trouble using a 1ton trolley jack and the weight of the truck to put the lower ball joint back in. Replace the nut and grease fitting.
The new ball joints will probably come with cotter pins, use them. Make sure the new joints are tight or they will wear the holes in the spindle. Don't forget to grease the new joints. Hope this helps.
Jul 13, 2009 | 1999 Chevrolet Silverado 1500
Honda 450 rebel fuel tank stud size?
I have a 1986 CMX 450 and have just found thru You Tube that you can use the extra capacity gas tank (3.4 gal) from the 250 to replace the 450 tank. Ordered it and it fits PERFECTLY. No retrofitting needed WHATSOEVER. Cost $99 on Ebay plus shipping. Arrived 2 days earlier than anticipated. VERY VERY HAPPY. I had too many holes in my old tank to even count them. LOL
Apr 04, 2009 | 1996 Honda CMX 250 Rebel
Cant find grease sert on front end? 06 ram 2500 4x4.
if there is no fitting it is a "sealed" joint... either drill out a hole in the end and add a fitting for grease.... or when it fails replace it with one that has a fitting. i believe most hardware stores stock grease fittings
Robert
Dec 19, 2008 | 2006 Dodge Ram 2500
Damaged grease fitting on upper control arm
It should have flat sides so a wrench or socket will fit it. As long as it does, u can remove it.
Oct 25, 2008 | 2002 Chevrolet Silverado
1999 Chev Blazer 6cyl 4.3L 4WD Rear Brake assy - I have replaced 2 Brake Pads and Rotor. After replacing and a test drive... Its making a scrapeing noise and now the rotor is extreamly hot and descolored....
I replaced the rotors and pads on my right hand drive Blazer and had the same problem ,dont worry in a couple of days normal running the pressure goes away and you dont get the heat problem.
Its just the new pads bedding in.
J.C.
U.K.
Jul 17, 2008 | 1999 Chevrolet Blazer
Boating Logo
49 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
