Question about Curtis Sylvania SDVD7014 DVD Player
My portable dvd player will not play it just says loading or no disc when one is in there
SOURCE: tf-dvd7005
Mine does the same thing! Help please!
Posted on Mar 17, 2007
abhi_patil
  • 569 Answers
SOURCE: no disc
check ur cd/dvd into other drive if it reads properly then there is the problem dvd player, try cleaning the lens
if it does not work take to service center
Posted on Nov 23, 2008
humbletech
  • 31 Answers
SOURCE: portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Posted on Dec 03, 2008
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
Posted on Jan 16, 2009
petraman7
  • 1175 Answers
SOURCE: my portable dvd player shows no disc when i put my dvd in player
Hi....
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
Posted on Feb 25, 2009
Portable GPX 931B dvd player, comes on, load disc, then displays wrong region, will not play the dvd.
Does this happen with every DVD you try to play?DVD's are often manufactured for different regions around the world.
Oct 30, 2013 | GPX Pd931b 9" Portable Dvd Player
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Dvd player says no disc when there is a disc in
Hi
Please check weather you have inserted the disc ,whose format is supported by your KOSS player.
If the formatt is not been supported /regonised by the player,It shows as NO DISC only.
check with some other disc which you previously played.If it plays the disc which you using has the problem.
Thanx
Jul 26, 2010 | Dynex DX-PDVD7 Portable DVD Player
My logik lpd850 portable dvd player is turning on but doesnt seem to play any discs it just keeps reading no disc any solutions please.
the fault is obviously from the laser (lens) of your player. The lens is very weak such that it cannot load/read data on discs.
The best to do now is to replace the lens and your player will play all discs again.
Take care.
Jun 04, 2010 | US Logic DVD800P Portable DVD Player
Our only one month old portable insignia dvd player will not read any dvd...get message stating "loading" or no disc...Please advise
try clean the lens with cotton buds gently/smoothly...try audio cd or vcd to play if it will play and not playing if the disc is dvd...lens for replacement partially burnt
Jan 03, 2010 | Insignia I-PD720 Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Portable dvd player showing"no valid disc"
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Problem with dvd player. Trutech 7 inch
I was told that they could reset it but I can not find a number on this company
Mar 20, 2008 | TruTech PVS12701 Portable DVD Player
Curtis Sylvania SDVD7014 DVD Player Logo
46 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
