Cd/dvd drive asks like it is not there - Computers & Internet
  • 77 Answers
Hi there!
Try to check your CD/DVD's IDE cable and power.
Be careful on opening the CPU. Follow the proper way of opening the CPU and checking those things to avoid accidents.
Hope this helps!
Posted on May 04, 2008
Format aspire4736z
Hi there.
To format you will need:
Operating Systems (OS) CD/DVD
Steps:
1) Enter the BIOS when the laptop boots by pressing the Delete key repeatedly.
2) Once the BIOS is open locate the boot disk priority and set prioity 1 to the CD/DVD drive, set priority 2 to the laptop's hard drive.
3) Save changes to the BIOS and exit. The system should now reboot.
4) Insert your OS CD/DVD.
5) Press Enter when the system asks you if you want to boot from the CD/DVD.
6) The OS setup should now start, the first thing it will ask you to do is format your hard drive.
7) After you drive is formatted you can either continue with the setup and install a fresh copy of the OS or you can exit leaving the main drive clean.
~ Slasher_X
Sep 25, 2011 | Computers & Internet
I have never burned a CD. I have need of burning two tonight. What do I do?
are you burning a cd or dvd? burning a cd is pretty easy...windows will do most of the work for you. put a blank cd in your cd rom/ dvd burner drive. it will ask you what you want to do with the blank cd...vista usually asks you to format the disk...select ok.....a blank box will pop up....drag and drop your files to be burned into the blank box.....once you are done putting your media onto the disc....eject the disk...before the drive opens a box at the bottom of the screen says that the disc is being prepared for use on other computers. when it ejects, it should be done....you can try to put it back in to the cd drive and see if your data/media files are on the disc. ......now burning a dvd is alot more complicated....do you have software for burning dvd media? if you do, they have help me files and tutorials........some more good advice....youtube also shows good tutorial vids on burning. just type in "burn a cd or dvd".
Oct 12, 2010 | Computers & Internet
Helloo, my cd/dvd drive can read cd but not dvd. i checked for the upperfilter n all the other filters in the driver register but dint find anything. but still its is not working. kindly find a...
the lens has lost its potential to read DVD... it is a common problem in Combo players... if you drive is in warranty you can ask for a replacement... or else add another drive to your computer... because repairing the drive will never make it to work better...
Aug 04, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dvd's & Cd's are not being read
When this happen the problem is usually the CD drive, even if a virus can cause same problem.
To test if the problem is software, go to bios or boot options, set primary bot device CD/DVD, and start the computer with a boot disk inside.When asked chose boot from CD.
If the computer does not see the dvd drive, and does not ask you if to boot from CD on this conditions, then you have a faulty DVD RW drive.
Try first removing the DVD drive and refitting it in place, after removing battery and unplugging the AC adapter cord.
If that does not work, you usually need to replace the driver, even if on rare circumstances a faulty motherboard can cause the same.
That is however quite unusual.
the most common is a faulty optical drive.
May 16, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Cd-rom drive broke , need to replace but dont know what will work
YOU CAN GET A ROM OFF OF EBAY, NEWEGG.COM OR WHAT I ACTUALLY SUGGEST IS BUYING AN EXTERNAL USB CD/DVD DRIVE. THEY ARE STILL AVAILABLE DON'T BELIEVE ALL THAT NONSENSE.
yep i just looked on newegg.com you can buy them brand new for $18.00 with cd and dvd or just cd
Mar 31, 2009 | Sampo DVE-620 DVD Player
LG 18x SuperMilti DVD Burner DVD=/-RW/DL/Ram Oem
Depends what software you are using to burn. Use Nero. then select dvd or cd or whatever. You must state what you are burning onto - you cant create a cd then put a blank dvd into the drive - common sense
Aug 15, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Magix Music Manager
Is it really asking you for ur software installation CD?
Most probably it may be asking you for your Operating System Installation CD. Please insert the Windows 2000 SP4 CD into the drive and try continuing with the installation
Best of luck
Have a nice day
Feb 01, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
