Question about Texas Instruments TI-Nspire Graphic Calculator
My TI nspire will not turn on with either keypad, and ihave tried changing the batteries mutiple times. help please?
Buy HP
Posted on Mar 09, 2011
How do you put the batteries in?
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press [On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc] [Enter] [EE], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at the top right of the TI-Nspire keypad and has a picture of a house on it.
Aug 26, 2011 | Texas Instruments TI-83 Plus Calculator
TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Nov 23, 2009 | Texas Instruments TI-Nspire Graphic...
My nspire is not turning on. i press the on button, but the screen is just blank.
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Oct 18, 2009 | Texas Instruments TI-Nspire Graphic...
Screen Failure
Here is what the TI knowledge base says about a calculator failing to turn on.
Sep 16, 2009 | Texas Instruments TI-Nspire Graphic...
Havent used my ti-inspire since last school year.wont turn on
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
TI-nspire screen doesn't work
My calc wont turn on at all no matter what i do.
Try these, courtesy of the TI Knowledge Base
Jul 23, 2009 | Texas Instruments TI-Nspire Graphic...
My TI-nspire CAS doesn't want to go on! I changed batteries! Tried the contrast buttons! Nothing works
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
Jun 10, 2009 | Texas Instruments TI-Nspire Graphic...
Mar 08, 2009 | Texas Instruments TI-Nspire Graphic...
Won't boot into new screen
  2. Hold down [Home] [Enter] [P], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Nov 22, 2008 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-Nspire Graphic Calculator Logo
123 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
