Question about GE Microwave Ovens
The display on the touch screen is not showing anything but the controls work, how do i fix that?
  • GE Master
  • 9,047 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, note your full model from the tag on the unit and check here for more information.
Posted on Aug 22, 2010
Shows "demo" and will not work
Pull the plug for a few seconds . Plug back in . With door closed try reseting clock . ( not recomended unless your a pro isid3 the main control typically behind pcb there is a chematick that will let you do a test on touch panel , pcb, and reseting the display etc.
Apr 30, 2016 | Panasonic Microwave Ovens
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
My TAPPAN Microwave Oven Model Type: TM5430 B only shows S1 in the display and it doesen't react if i push any othetr buttons. What can i do ???
Unplug the unit, let it sit for a minute to clear power from the control board then plug it back in. If the display still shows S1, that could indicate a bad touch switch on the front panel, a bad connection between the touch panel and the control or a failure in the control. Unless you can get parts cheap and fix it your self, it's not worth paying for the repair.
Jul 08, 2011 | Tappan Microwave Ovens
Touch screen fading in & out, unit works fine
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Jul 27, 2010 | Dacor DMT2420SS Microwave Oven
Touch pad not responding
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Nov 23, 2009 | Whirlpool GH6177XPS Microwave Oven
Display shows 6's across screen & beeps
HI. the touch pad board is malfunctioning at this time. you will need to replace this damaged touch pad device asap. this will fix your issue.
Sep 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F2 on display with controls non functional
HI. this is a code that represents a failed key pad or touch pad membrane board. replacing this failed touch pad will fix this issue. This touch pad board is separate from the actual control board.
Aug 13, 2009 | KitchenAid KHMS155L Microwave Oven
Dacor Touch Screen is flickering and doesn't respond to touch
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
