Question about Husqvarna Sewing Machines
The thread is knoting and pulling the fabric threads...What do I need to do?
  • 35 Answers
Make sure it is threaded correctly
Make sure needle is large enough for the thread
Check bobbin tension to make sure it's not too tight
Make sure adjustment of machine (stitch length etc.) is correct for the specific stitch you are using.
This is my best advice with the information that is given.
Posted on Aug 23, 2010
What is the problem when sewing the top thread can be pulled right out and the material puckers up
So, it sounds like the bobbin thread is coming to the top of the fabric and the top thread simply lays on top of the fabric. Just a hint: If the thread problem appears on top of the fabric, it is usually a bobbin thread problem. If the thread problem appears under the fabric, it is a top thread problem.
Is the top thread tight, ie pulling the bobbin thread up? Try loosening the top tension.
If that doesn't resolve the problem, then you probably need to tighten the bobbin tension.
Understanding Thread Tension on Your Sewing Machine
Jun 08, 2018 | Sewing Machines
Necci 752 manual is needed.problem with threading and stitching
Hm, I'm not able to locate a manual but may be able to offer some suggestions.
Remove the top thread from the machine.
AVOID OLD OR BARGAIN BIN THREAD!
Use the same thread in top and bobbin.
Be sure to use a brand new needle--needs to be compatible with the thread and fabric of the project..
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point.
Verify the bobbin is loaded and threaded correctly and it turns the correct direction.
Pull the bobbin thread up through the fabric before taking the first stitch. It also helps to hold both thread tails in your left hand when taking the first stitches.
Test your machine and tweak the top tension until the top and bobbin threads meet in the middle of the fabric. (Increased top tension will pull the bobbin thread up. Decreased top tension will allow the bobbin thread to pull the top thread down.)
How to Thread Necchi Sewing Machine
How to Thread Necchi 535FA 535 534FB 534 Sewing Machine and Bobbin Case (not your model, but the threading and basic instructions will be similar or the same as your machine)
How to thread Necchi model 535 FA sewing machine now with captions
Mar 18, 2018 | Sewing Machines
Brother SE400 :When I pull on the fabric's sewn part one of the threads slides back and forth. I can then pull on one of the threads-it slides out and the other thread is easily lifted up. How to fix?
Your stitches may be too far apart. But, most likely the issue is that the tensions are not correct. If one thread lays in a smooth straight line on the fabric, the other thread tension is too loose, ie the bobbin thread lays on the fabric and the top thread is going all the way through the fabric and shows on the bobbin side, then the top tension needs to be tightened. The tensions are correct when both threads meet in the middle of the fabric.
Sep 14, 2017 | Brother Sewing Machines
Thread bunching up on bottom of fabric
Remove the top thread from your machine (NOTE: ALWAYS clip the thread next to the spool, lift the presser foot, and gently pull the top thread down from top to bottom!!! This helps reduce the chances of breaking something by pulling the thread upwards!)
ALWAYS RAISE the presser foot and rethread the top thread from beginning. Verify the thread path is correct and start out with the thread tension set at the midway point (and then tweak the top thread tension through testing).
FWIW, if the thread problem appears under the fabric, it is generally a top thread issue. If the thread problem appears on the top of the fabric, it is generally a bobbin thread issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
CURED Sewing Thread Nests on the bottom
Jul 04, 2017 | Sewing Machines
How to adjust the tension
The standard factory tension setting is the midpoint--midway between the highest and lowest. Tension will need to be adjusted to suit the needle, thread, and fabric for the current project. A sewist should be comfortable making these adjustments to achieve the best tension. The correct tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric--neither the bobbin thread is pulled to the top of the fabric nor is the upper thread being pulled to the underside of the fabric.
Oct 21, 2015 | Elna 2005 Mechanical Sewing Machine
Pulls bottom colored thread to top...how do I ajust New Home 8000 trying to zig zag and bottom thread pulls color to top....
The bottom thread is the bobbin thread and it is suppose the pull the top thread slightly to the bottom/center of the layers of fabric.
Try a lower tension setting and a tear-away stabilizer or sheet of printer paper under the fabric to see if this will help hold the top thread down into the fabric.
Mar 27, 2010 | Sewing Machines
The thread after sewing just pulls right out won't sew
the thread hook is not grabbing the thread; it is not turning around and, knoting the needle and, bobbin threads together.
pull the cover off under the bobbin so you can see the hook: it looks like a small disk with a point on it) turn the wheel so that the needle goes down and, see why the hook is missing the thread then: adjust the hook so it just passes through the needle loop when the needle starts back up.
Jan 16, 2010 | Singer Sewing Machines
When sewing elastic type material it keeps knoting
you may need to use a certain type of thread for jersey knits and stretch fabrics also your machine should have a setting for stretch stitches to allow for smoother sewing
Dec 11, 2009 | Janome Memory Craft 5700
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Sep 23, 2009 | Brother CS-100-T Computerized Sewing...
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
