Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Ice wont eject from mold - Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
  • 37 Answers
Lglasoe --
Owners Manual is available online at:
[http://www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+655532]
If ice is getting stuck in the mold, it usually can be removed using a plastic (not metal) tool to eject it. Sometimes using a cooking spray like PAM (very lightly) on the ice mold can reduce the tendency for the cubes to stick. If you are still having a problem, write back. -- SWT
Posted on Aug 22, 2010
Coating on maytag ice maker mold peeling & flaking
In this case you have to replace the entire ice maker since the mold section is not sold separately. If you shop carefully you can get the entire shebang for about 40 bucks on ebay.
Feb 21, 2016 | Maytag Refrigerators
Ice Maker Failing to Eject Ice
icemaker not making ice video-
Nov 23, 2014 | GE Refrigerators
Ice maker not making ice
Check and see if a cubes or cubes are stuck in the ejection fingers. If the ice mold is full try cleaning the bottom coils. If the ice mold is empty check the water valve solenoid. Most times both the ice maker and water valve gets replaced at the same time. Nothing inside the ice box controls the ice maker. It does it all itself all it needs is for their to be 35f in the freezer or better.
Apr 06, 2014 | Amana ARSE66MB Side by Side Refrigerator
Ice cubes won't eject
if they will not eject . then i would think the mold & or heater have failed . it works like this . it fills / it freezes/ ( the freezer must be 15 deg or lower for ice mker to cycle . ( cck the tempt ) and if ok then the thermo cycles the ice mker . during the harvest cycle the mold heater comes on and warms the mold and releases the ice. the hands move the ice out . .. so if cold enough the ice mker is bad. cheaper to repl ice mker than repair it . in most cases . mm hope this helped feed back pls ..
Oct 21, 2010 | Maytag PTB19BBGR Top Freezer Refrigerator
The ice maker is not able to eject the ice cubes. You can see them partially exposed but they will not move. The unit keeps making noise...I assume it is trying to eject the cubes. How do I resolve this...
the under side of ice maker should be very warm. this is the heater that warms the ice mold . if its not hot ( warm) the the ice harvest is slow or not at all . if heater is bad or mold ruff or warn out . the ice mker wil have to be replaced . you can clean tray and use a food grade silcone and it will help if heater is ok .. mm .ps some times the ice cubes are too small and get jambed in the slots . if so adjust the cube side ( more water adjustment . this will correct the problem mm ..
Aug 17, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Ice maker doesnt eject ice cubes until i physically help turn the the timer
Hello. Turn off the water to the ice maker. Remove the ice cubes, use a blow dryer to dry the mold and then spray the mold with PAM cooking spray. Let that dry and then turn the water to the ice maker back on. Joe
May 05, 2010 | U-Line Icemaker
Ice maker cannot eject cubes. I took off the front cover and found several contact points for checking the motor, water valve, thermostat, mold heater. There is also a line voltage and neutral contact. Are...
I usually replace icemakers as a unit. It sounds like the mold heater is out. The system cycles like this: Fill, freeze, mold heat, eject, and start over. The mold heater not working will prevent ejection.
Sep 09, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Shot Mold Heater?
The mold heater comes on shortly before the ice is dispensed. It warms up the mold so that the ice releases. The heater, if not working could cause the water to overflow as the ice can not be ejected if the heater does not work. That woud make the appearance that the ice melted and refroze.
Jun 04, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice maker is not ejecting the ice cubes
sounds like you have an issue withthe ice maker mold heater, not afield servicable part, replace the entire ice maker a assy, easy to do 2-3 screws and a wire harness
Oct 24, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice Maker Infrared light doesn't light
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Sep 18, 2008 | KitchenAid KSRG25FK Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
131 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
