Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas
I have an operating inground spa heated by solar and by a Teledyne-Laars 325,000 btu natural gas heating unit. It operates by using a hand held remote system. It was operating fine until the gas was turned off in order to fumigate my home last week. When the gas company came to turn the gas back on all gas operated units were checked, including the spa heater. The unit activated upon 'call', turned on the gas pilot light and tried to activate the gas burners but could not do so. Several times we turned on and off the heater with the same results. We could hear it operating but the assembly would not let the gas burner activate. The gas company technician said he believed that there is a float device which was 'stuck...'. What is your advice/cure. We knock on the housing of the system, but that did not make it happen. I tried several time again yesterday to have it activate, with the same results...Thanks for a response to my inquiry. Jim Connor 858 922 5968
    Genius:
  • 1,340 Answers
I think you have air in the line.You just need to bleed it out somehow and it should fire right up.
Posted on Aug 22, 2010
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
What is the different between BTU and K
BTU is British thermal units for measuring heat and Kilowatts is the measure for power usage
Oct 08, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Spa heater turns on and shuts down before spa heats up. what is the problem?
could be a dirty filter not enough flow of water,pump could be sucking air ..do not adjust the pressure switch ..as last resort take pressure swich out (its attached to copper tube in the front and make sure its not clogged ...best bet is pump problem sucking air or dirty filter good luck www.dollarspa@aol.com
Jan 02, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Do you know the btu rating for Teledyne Laars Mark V
All heaters have a data plate. Often the model # is the BTU's. For example, H400 is a 400,000 BTU output. The plate is on the inner firewall. All heater have different BTU's.
Aug 22, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Electronic pilot lights but unit will not fire
Make sure the pipes are full of water. Check the thermostat to see if it is calling for heat. Make sure the thermostat is set to a temperature higher than the current temp of the water. If all those things are OK then the gas valve coils may have to be replaced.
Jul 19, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Piolet stays on,. burners do not go on heater will not start
could be many things ,start with pressure switch,check for continuity with multi-meter.if press switch isnt sensing water flow, your unit will not call for heat.let me know
Jul 04, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas  Logo
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
