Question about Holland Grill Classic II (NG)
I hav a single burner holland grill. When I light it it often times goes out after a few minutes. Relighting often does same thing, sometimes it will stay on. Ive adjusted the flame to various settings but still same. There is a heavy gas smell after it goes out, and found out the hard way to open top and let air out good first after loosing much arm hair.
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: Bright yellow flame, can't adjust
Check your burner tubes for spider nests. Clean the burner assembly and check all the holes. Eric
Posted on Aug 08, 2009
Grill troubleshooting
I'll take a shot in the dark that your problem is with how you turn on the gas.
Try this: Turn off the burners and the gas. Wait a minute or two.. Turn on the gas about 1/8th turn. Wait half a minute. Turn on and light the burners.
Hopefully this solves your problem.
Jul 20, 2014 | GrillPro Backyard Grill 5-Burner Stainless...
Grill does not get as hot as it used to.
You may have already tried this but sometimes the safety devices on the tank will engage, resulting in a weaker than normal flame and little to no real heating. Try this. Ensure that the valve on the tank is off. Then turn the grill valve on to release any gas that may be in the lines. Turn the grill valve back off, and turn the tannk valve on. You may hear a click as those safeties kick off. Then try to light your grill and see if the flames are normal. Always remember that the valve on the tank should always be turned on first, then the grill valve. Also the tank should always be turned off first, and then the grill valve. That may not be your problem, but I've seen it happen many times.
Apr 20, 2010 | Holland Grill Heritage (NG)
Not enough gas/flame.
You probably have water in the burners. If you can get one burner to light, let it warm up the grill and maybe it will dry out the others.
Apr 07, 2010 | Char-Broil Advantage 463453306
Back Burner sometimes goes out when close grill -relights wn open
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Apr 06, 2010 | Weber Genesis Silver B Grill
Grill's fire won't stay lit
Try banging on the tubes feeding the burners with a heavy pair of vice grips or a hammer. It usually shakes the carbon loose to allow for free flow of gas.
Aug 09, 2009 | Grilling
Aug 08, 2009 | Holland Grill Legacy (NG)
Jenn Air 720-0061-LP Gas Grill Rotisserie Problem
Hi all ,
I just bought a jenn air 720-0336 gas grill from bj's . the rear rotisserie burner would stop working after a few minutes .
hear is the deal , the rear inferred burner gets to HOT . they did not put any insulation between the ceramic blocks and the metal bezel.My fix was to remove the unit , drill out the 8 rivets holding the bezel on , carfully remove the bezel and install a fire proof gasket , i was abile to find the proper stuff at my local coal / wood stove retailer.it comes in a white sheet about 1/8 inch thick .
use steel rivets to reassemble . good luck . this took a week of trial and error to figure out .
Aug 02, 2008 | Grilling
Temp
Not sure on your climate.
But a Holland grill cooks cooler in the coller months and Hotter in the hotter months. This type of grill doesn't reach a very high setting approx: 400 degrees. It might reach higher temperatures in the hotter weather 450-475 degrees.
Also, it has to shut down the same way every time you use your grill.
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Hollands are known for the slow cooking process and a Healthy way of cooking!
Apr 27, 2008 | Grilling
Holland Grill Classic II (NG) Logo
53 people viewed this question
Top Holland Grill Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Holland Grill Grilling Expert? Answer questions, earn points and help others
