Question about Aiptek DV8800 Digital Camera
Audio delay every time i record a video, the audio and visual never match up
  • jweezys Jul 18, 2008
    My sound and my video do not match up.
  • viburns Sep 19, 2008
    I have the same problem - is it the camera or movie editting?
    Problem Solver:
  • 5 Answers
There is no way to fix that
Posted on Jun 16, 2008
Can I run a cable from RCA out on my amplifier to 3.5 mini external microphone socket on my Panasonic HC-V770M camcorder, so the camcorder only records what is coming out of the amplifier
You could run the cable, sure, but the recording levels may not match, or there may be other interference issues. If, as I suspect, you wish to add an audio soundtrack to your videos, the easiest way is to use some kind of audio/visual mixer, input only the video from the recorded tapes (or whatever), then feed the amp output to a separate audio channel on the mixer. This will give you the facility to adjust gain, and you can feed the combined output to your computer to crate the finished video. See you at Cannes !
Mar 28, 2017 | Panasonic Video Cameras
Audio lagging behind video
It is much eaiser to delay then to go into the fugure. try delaying the video.
Feb 27, 2014 | Audio Players & Recorders
My sound isn't matching up to my picture
Some cable service providers have a delay in video and audio. It is most likely an issue with your service rpovider. There is a delay in the video or audio. This is not uncommon with some channels.
Sep 21, 2012 | Televison & Video
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
Feb 11, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Audio time delay Bush 21" LCD tv
TV ng - return for exchange if new.
Jun 20, 2017 | Televison & Video
There is a 1 second delay from the time i play to
adjust your audio buffers, if your recording software allows it. however, there will always be some latency in usb recording devices. i recommend firewire or pci internal cards for recording.
Nov 30, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Suddenly the A/V recording is out of sync
If you have recently added and other audio / video software it is quite possible that it may have introduced some extra "codecs"
Too many or the wrong kind can have this type of impact
As can a bad player.
If you did then un-install it inc any extras or other settings it may have made.
If you have changed the format that you record in this too can cause issues esp. if the wrong codecs / player is installed.
Many video conversion utilities can play a part too.
These are all areas I would suggest you look at.
Aug 27, 2009 | Logitech Computers & Internet
Audio is out of sync with video
what are the connections supported on your pioneer player? i suggest try to isolate problem, change the type of cables, like RCA or HDMI cables.
Jan 24, 2007 | Samsung DVD-R130 DVD Recorder
Aiptek DV8800 Digital Camera Logo
29 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
