Toshiba Model 37HL17 is juat over two years old, shows red/orange color problems where the colors seem to glow or effervese very strongly, along with pixels/squares visible in the colors. Has been getting progressively worse. Present on both HDMI and component inputs (from DVD). Dealer says LCD screen and built in module need replacing. That fix will buy me three TVs!! Help!
  • 2 more comments
  • millavemike Aug 24, 2010
    Some web postings I saw mentioned a firmware update and/or a calibration. Any chance of that? FYI, the dealer called this "solarization". Thx
  • millavemike Aug 25, 2010
    The two suggested solutions, first an inverter board, then a display panel, doesnt seem to be a definitive response. Isnt there a single board or module these symptoms suggest is bad, or even firmware as suggested?
  • millavemike Aug 28, 2010
    I havent bought a t-con board yet but I did locate one.i will probably replace it when the picture gets worse. I remember the repair shop saying it could be the tcon board themselves, but oddly could not locate one. So for now this seems like a solution.
    I browsed and chatted, and found that this solution seems to fit best. I will update when I replace the part. Thanks.
  • 4,889 Answers
How can he say that so confidently? The first thing to try would be the t-con board itself. Its also called LCD driver board and is capable of causing the problem you have described. I suggest you replace it and see if it resolves the issue. Should cost you around 75-100$
Posted on Aug 25, 2010
  • eagle338
    eagle338 Aug 28, 2010
    If the issue is resolved then please click the accept button next to MY solution. Sai.
  • eagle338
    Thnak you for the accept :). Thanks for using Fixya. Sure, update me after replacing or before replacing if you need any advice.
    Sai.
  • 5,138 Answers
Your inverter board is more then likley to be bad ,which unless you bought extended warranty their is none avaiable.
Posted on Aug 23, 2010
  • 1 more comment
  • ladywinn
    ladywinn Aug 24, 2010
    Its a good chance its your display Panel. Go to Ebay Look under Electronics and TV/Parts
  • ladywinn
    ladywinn Aug 25, 2010
    Display Panel !
  • ladywinn
    ladywinn Aug 28, 2010
    I did some checking and it very well could be the Tcon board Part number is 75009041
    Encompass Parts Distrbution has 1 in stock Price after core refund is $278.41 (1-800-638-3328)
    Go to Ebay Look under Electronics TV Parts type in Part number,sometimes you can find Part alot cheaper then other companys.If the Tcon Board does not correct problem then it will be in the Display panel.
Color diagram for a clarion radio
If this is a factory radio - the year would be required.
However just before 2000 model year... and for a couple years after - the following wiring colors are prettymuch constant....
Constant 12V+ Red/White Switched 12V+ Red/Yellow Ground Black Illumination Green/Red Dimmer Red/Yellow Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Blue Left Front (-) Yellow Right Front (+) Green Right Front (-) Gray Rear Speakers 4" Roof Mount Left Rear (+) Orange Left Rear (-) White Right Rear (+) Orange/Blue Right Rear (-) Orange/White
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 07, 2010 | Clarion Car Audio & Video
Toshiba Integrated High Def LCD TV
have you tried reseating the cables from the back of your tv? try unplugging it and replug it.
keep me posted, thanks!
Jun 07, 2008 | Toshiba P42LSA 42 in. LCD Television
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
Dell monitor 152fpc orange coloring replacing red
If you connect the monitor to a laptop's "video-out", do you get correct colours, or do you still get the "orange" ??
If so, then the monitor is the problem.
Apr 17, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
No color when turned on, after a while it color returns.
This is a cold solder joint in the signal section of the set. After it heats up, that problem area conducts better. Have an experienced electronic person reflow some solder on the board.
Feb 02, 2009 | Toshiba 32AF43 32" TV
Blinking led light on Toshiba
wow i must be another one with this toshiba common problem bug. Has anyone even remotely helped on this site?
Feb 27, 2008 | Toshiba TP50F50/51 50" Rear Projection...
No Red in the picture
Could be faulty red socket along w/ ballast. You need tech to see this.
Dec 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
chris
Aug 04, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
