Question about Home
Keeps cutting on after bowel empties. - Home
  • 1 more comment
  • Bruce Hathcock Aug 22, 2010
    What keeps comming on? the water?
  • morris_stron Aug 22, 2010
    The pump cuts on and then off and then on and off every 30 seconds even when the bowel is 95% empty. It pumps continuously when you flush it and then cuts off when 95% empty and then on and off every 30 seconds. It only stays on for 2-3 seconds.
    The pump cuts on and off after the bowel is empty
  • 4 Answers
Sounds like my bowels after I eat Mexicans
Posted on Oct 18, 2011
Is the bowel from the Hamilton beach slow cooker model33133hw oven safe
Hello, Huston -
Clarification: You are asking about the stoneware bowl (not bowel) for the Hamilton Beach slow cooker, model 33133hw.
If so . . .
Page 3 of the manual for that model of slow cooker states:
(Quote)
The Stoneware is microwave save and oven proof, but never heat the Stoneware when empty.
(End quote)
In case you do not have the owner's manual for the slow cooker, this is the link to web page from which you can download and save it:
https://all-guides.com/manual/390463/hamilton-beach-33133-operation-user-s-manual-44.html?page=1
Best wishes.
Mar 25, 2018 | Hamilton Beach Crock Pots & Slow Cookers
Good day my name is michael ,my wife had a problem with her belly button it keeps swelling & when the pain starts ,she cant even bent.what can i get her for pain/any advice please?
if it is an abdominal hernia and she is in pain her bowel might be being pinched . If her bowel is pinched it is an urgent life threatening condition ! Seek medical assistance
http://www.healthline.com/health/hernia?algo=true#overview1
I am speaking from my own experience from having a belly button that was sticking out (Umbilical hernia) that I was advised to get an operation to fix the hernia and that there was a risk of having my bowel getting pinched which is life threatening !
Had a hernia operation to fix it. Was also there when I was a baby but it sealed up but came back later in life .
http://www.healthline.com/health/umbilical-hernia#symptoms3
Advise getting an ambulance if the pain is intense.
Aug 02, 2017 | The Health & Beauty
Early symptoms of bowel cancer
none in a lot of cases
had a friend who had no symptoms but later on did and half her bowel had to be removed. (her mother had history of bowel cancer)
http://www.cancervic.org.au/preventing-cancer/attend-screening/bowel_cancer_screening&utm_source=google&utm_medium=cpc&utm_content=bowel-screening&utm_campaign=Prevention
get a test for blood in stool
or if family history of bowel cancer consider getting a camera inserted in bowels procedure at medical facility. called a colonoscopy .
Dec 04, 2016 | Health & Beauty
What does IBD mean i court
Definition of IBD (inflammatory bowel disease) - MedicineNet
www.medicinenet.com > ... > digestion az list > medterms medical dictionary az list
  1. Cached
  2. Similar
IBD (inflammatory bowel disease): A group of chronic intestinal diseases characterized by inflammation of the bowel -- the large or small intestine. The most common types of inflammatory bowel disease are ulcerative colitis and Crohn's disease. What does IBD mean Google Search
Nov 23, 2016 | Cars & Trucks
Water keeps running & overflows
The machine has a cut off inside that should cut supply when enough has entered so cut off or sensor fault try run it empty see if its actally overfilling as the pump should remove excess i may be blocked
Apr 10, 2016 | Simpson Esprit 750 Top Load 7.5kg
My craftman lawn tractor run for a while then stalls . the gas filter is empty when it stalls
Sounds like your fuel bowel is dirty or your fuel jet it the bolt that holds the fuel bowel on is plugged.
Take the bowel off and clean it real good and also blow the jets that are in the bolt that you took off . Carburetor cleaner would also be good as well. i also had a mower the tube in the gas tank was dirty on the end where the gas is sucked in I took the tank off and cleaned the tube and put clean gas it the tank. Away she went.
Oct 07, 2014 | Garden
Spitting petrol out side of carb
Your float is stuck or your float needle and seat are not seating well, allowing the fuel height to rise too high which then comes out the side. This is assuming that your float is adjusted properly in the first place. Pull the carb and pull the bowl and check for dirt in the bowel, check the needle and needle seat. check float height. You can also open the bowel drain, before you take anything apart, drain the carb. Turn the fuel on and see if you can flush it out after the bowel has emptied. You can also spray carb cleaner in the fuel inlet on the carb with the drain open and the carb empty. Not really a fix but might get you by for a while.
Mar 07, 2014 | Motorcycles
LIGHT FLASHING EMPTY WATER,CUTTING OFF WHEN WATER EMPTIED
Try cleaning the water sensor, it may need to be replaced though.
Dec 22, 2013 | Dryers
STX 38 Ride-on mower, Motor runs in neutral, but cuts out when you engage a gear, also cuts out when you switch on blades
Check for build up around blades. But it sound as your fuel bowel is clogged or your carb needs cleaning.
Nov 09, 2012 | Garden
Last night I was driving my 1996 volvo 850 and white smoke came out from under the passenger side of the hood. I added coolant because the resevoir was empty. The coolant bubbled a lot. This afternoon I...
it could be a blown head gasket or could be a stuck thermostat causing the coolant to bowel and the only place to go is out the resevoir bottle pull your oil dipstick check to see if you can see little water bubbles in the oil on the stick this kinda gives you an idea if the head gasket is blown because most of the time the coolant will mix with the oil if the thermostat is stuck close it will lead to a blown head gasket if you dont get it taken care of also you may have a slow leak in the water pump and once the level gets low its going to bowel whats left and the stem will come out the over flow tube on the bottle
Sep 18, 2010 | 1995 Volvo 850
Home Logo
51 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
